Dear all,
Thanks to the help of Alan and Alexandra I can finally upload large animations in Flickr and embed the gif BBCode (of the original!) here without overloading the solarchat page! Hope everything works fine and we can enjoy looping animated gifs now, as long as my disk space and the clouds will allow! :-) :-) :-) Next month I will leave for more than a month for research expeditions out in the sea and all the amazing experience with the sun will stop for a while, so I try to enjoy the scope, the summer clear skies, the acceptable seeing and our forum as much as possible these last days.
The following is the uncropped animation of two days ago. I had posted earlier just the active area with the penumbral waves of the AR12833, since the size of the full frame animation presented here was 135Mbs...
Hope you will like it. Especially the fact that the sun's rotation starts to be visible now, especially if you focus on the right side at the limb.
Lunt130MT masked @102 mm, ASI290MM, 115 frames during 111 minutes.
PLEASE allow for the animation to properly and fully load to enjoy it. Now it loads much faster!
IF YOU WISH TO WATCH IT AT FULL RESOLUTION, please open in a new tab (Flickr), click on the right bottom download symbol and select either ORIGINAL size to open it in your Media Viewer, or VIEW ALL SIZES and then select ORIGINAL size to watch it animated in Flickr.
19 June 2021, 111 Minutes Animation of full NW by H- Alpha, on Flickr
Best wishes to all with lovely clear skies!
Alexandros
Animation of NW Sun, 19 June 2021, 111 minutes, 115 frames
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Alexandros
Greece
Greece
- cmas
- Has thanked: 294 times
- Been thanked: 248 times
Re: Animation of NW Sun, 19 June 2021, 111 minutes, 115 frames
Wow. There is so much going on in this. The active region, the rotation and then action on the limb. This might be the best animation I have seen as this looks good when looking at the whole frame and if one zooms to the active region there is a separate show available.
Images in AstroBin
Images in Flickr
Images in AstroBin
Images in Flickr
- Has thanked: 1640 times
- Been thanked: 878 times
- H-Alpha
Thanks a lot Alan!
And many thanks for showing me the way to use Flickr!
Alexandros
Alexandros
Alexandros
Greece
Greece
- Been thanked: 4904 times
Alexandros, a very good animation.
Well done.
Well done.
- Has thanked: 20435 times
- Been thanked: 10245 times
Very impressive!
- H-Alpha
Thanks a lot Eric and Mark!
I am very glad you liked it.
Best wishes to both of you,
Alexandros
Alexandros
Alexandros
Greece
Greece
- Been thanked: 8789 times
Isn't great to see the Sun rotate!
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Fantastic video... 111 minutes it's definitely beyond my patience
Raf
- H-Alpha
Many thanks Alexandra and Raf!
Imagine that today I reached 2h and 40 min!
And I have to correct manually the tracking every 2-3 captures, because while waiting for the HQ6 that I have ordered, I have only an old rented equatorial that isn't best quality...
I may upload the long animation later. The prom is fantastic together with AR, but 1/3 of the end of the animation is too blurry because of seeing deterioration...
No problem though! The goal is still alive and waits for better and longer lasting seeing!
Alexandros
krakatoa1883 wrote: ↑Tue Jun 22, 2021 1:48 pm Fantastic video... 111 minutes it's definitely beyond my patience
Alexandros
Alexandros
Greece
Greece
