June 18, 22 2021 AR12833 WL C11
- Has thanked: 1262 times
- Been thanked: 1057 times
Hi all
2 images of the same AR12833 made on June, 18 and 22, with C11 setup.
Both sessions with Aries DERF instead of front solar filter, UV/IR+Baader SC and ASI174. The only difference is ES 3x extender in the first case, TZ-4 in the second one. 0 gain, 0,15-0,2ms only. Than I changed to Ha with Quark, but not processed yet. I suppose TZ gives better picture regarding the same seeing.
regards
Leo
regards
Leo
- June 18
- Sun_20210622 101305_AId2Ps_850.jpg (446.9 KiB) Viewed 747 times
- June 22
- Sun_20210622 100102_AIdPs_850.jpg (401.86 KiB) Viewed 747 times
- Has thanked: 38 times
- Been thanked: 185 times
Re: June 18, 22 2021 AR12833 WL C11
Nice images. It’s interesting to compare what you get from your 11 Vs my 9.25. I think capture and post processing will however have a significant impact on the final image though.
Freddie
Ha: 152mm, Quark, ASI174m
WL: CPC9.25, ASI120m
- Has thanked: 9145 times
- Been thanked: 6027 times
An exceptional close up, Leo. Large difference between the first and second image, though.
- Has thanked: 20442 times
- Been thanked: 10248 times
Interesting comparison Leo... Are both post processed the same? The first seems like it is sharpened at a larger kernel size.
- Has thanked: 17672 times
- Been thanked: 8793 times
Absolutely delightful I think I prefer the first image though
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Impressive Hi-Res Leo!
I was thinking about buying the TZ-4. Do you have it for along time? Is it really good and useful?
Do you think it is useful only for Hi-Res scopes or it could work with the Lunt130 as well?
I am eager to see your photo with in in H-alpha.
Thanks for sharing.
Best wishes,
Alexandros
Thanks for sharing.
Best wishes,
Alexandros
Alexandros
Greece
Greece
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
Excellent high-res Leo. I also like the first one the best!
Arne
Arne
Re: June 18, 22 2021 AR12833 WL C11 Ha added
Thanks to all for your kind comments!
Well, I have to be more accurate with comparison, Mark, making all processing in the same way, but at least I see your different opinions )
Alexandros, I used TZ-4 some time only in Ca and WL, I can say I like what came out at all.
Now I almost finished to work out hi-res files in Ha from June 18 and 22, nothing to compare because of better seeing on 22 and, at the end of session with mostly ruined conditions, I catched bright Ellerman bomb right on the forming light bridge in umbra part of AR12833 spot.The all phenomenon cycle was visible withing 3-4 minutes, that's why I suggest it's EB, not a surge-like plasma ejections directly towards up, when significant flux change over hours. It was very bright and clearly visible in Ha core, not in shared blue wing under fibrils of chromosphere around AR, as usual. Magnetic flux reconnections should be very strong there in the umbra area.
The setup is the same as above, Quark with 0.5x, EB images without, cropped.
I can't make all nice, dark, long filament together with AR area, because of not stable seeing and forced to cut off a big part.
To see mosaic in full resolution, click on, please. I made proportions also to fit better your smartphones screens
thanks for looking
Leo
thanks for looking
Leo
- mosaic
- Sun 20210622 103440 104801 C Ps_AI.jpg (1.77 MiB) Viewed 659 times
- AR12833
- Sun_20210622 105431_cAIdOPs.jpg (507.99 KiB) Viewed 659 times
- EB
- Sun_20210622 114107_114442 AIwOP67.jpg (282.39 KiB) Viewed 659 times
- cmas
- Has thanked: 294 times
- Been thanked: 248 times
Nice and very detailed stuff!
H-alpha: Baader D-ERF, Sharpstar 61 EDPH II, Altair Astro 102 f/7, Quark, reducer and ASI174mm.
White light: Baader ASSF 115, Sony SEL 200600G, Sony SEL20TC, Sony A7iii.
Images in AstroBin
Images in Flickr
Images in AstroBin
Images in Flickr
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Top H-alpha images, really impressive!
- Been thanked: 4340 times
Outstanding series of image Leo...excellent work
