Not quite heads up for 24th June
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Hi all Screenshots and a small surge associated with plage area in the South Eastern quadrant. Some lovely prom activity still today too. Screenshots for ref. Some single frames included for the small surge.
- 20210624-141541UTellabryant-FDHA-proms.png (1.3 MiB) Viewed 275 times
- 20210624-123815UTellabryantFDHA-Small South Eastern Surge Prom.png (2.93 MiB) Viewed 275 times
- 20210624-125137UTellabryant-HA-Surge.png (1.65 MiB) Viewed 275 times
- 20210624-125339UTellabryant-HA-Surge.png (2.35 MiB) Viewed 275 times
- Screenshot (200).png (857.21 KiB) Viewed 275 times
- Screenshot (201).png (594.91 KiB) Viewed 275 times
- Screenshot (202).png (459.07 KiB) Viewed 275 times
- Screenshot (203).png (486.35 KiB) Viewed 275 times
- Screenshot (206).png (1.06 MiB) Viewed 275 times
- Screenshot (204).png (1.12 MiB) Viewed 275 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Re: Not quite heads up for 24th June
Hello again Ella. I can see in your captures the "surge" you mentioned previously in my post. There's around four-hours difference between the two, so I was having a garden-lunch around that time, but you've captured it well.
Good to see a nice display of the proms, where yours were similar to mine and showing the difference the 4-hours made..
Thanks for sharing
Thanks for sharing
- Has thanked: 17970 times
- Been thanked: 8905 times
Definitely a little bump of activity on the eastern limb, great shots
- Has thanked: 20779 times
- Been thanked: 10462 times
Nice grabs Ella! Just try and keep the file size of the uploads down if you can.
- Stardust5858
Will try Mark, they were straight off the computer in the dome which has basic capture, autostakker and ImPPG on it so that's my excuse, lol. Sorrieeeeee.marktownley wrote: ↑Thu Jun 24, 2021 3:25 pm Nice grabs Ella! Just try and keep the file size of the uploads down if you can.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Terry, that's what you get when you have lunch, I don't do lunch, just breakfast and dinner, lol.EGRAY_OBSERVATORY wrote: ↑Thu Jun 24, 2021 2:45 pm Hello again Ella. I can see in your captures the "surge" you mentioned previously in my post. There's around four-hours difference between the two, so I was having a garden-lunch around that time, but you've captured it well.
Thanks for sharing
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 8543 times
- Been thanked: 8280 times
Cracking proms, Nigella.
