Today I was almost clouded out completely. I had no breaks in the overhead cloud deck from home in the morning hours. Later in the early afternoon I had a very brief view using my very portable Lunt 8x32 WL solar binoculars from my daughter's home in Weaverville N.C. Using the SUNoculars I could see the spot groups of AR12842 in the NW and the now numbered AR12845 in the south-central area of the disc. Despite the low magnification I could see that they were more than just a single spot in the groups. I tried for the small spot(s) in AR12844 but they are much to small to see at this meager magnification.
Heavy rain moved in later in the afternoon.
July 18 2021 Observations. 8x32 quick view.
- Has thanked: 17863 times
- Been thanked: 17007 times
- Has thanked: 8559 times
- Been thanked: 8300 times
Re: July 18 2021 Observations. 8x32 quick view.
Hi James,
Hopefully the weather will improve for you shortly.
Stu,
The next two days don't look good. Thunderstorms and rain are predicted.
- Been thanked: 8907 times
At least the Sunoculars are portable for a quick view anywhere and you could see the tiny spots in both regions. They are small so the Sunoculars must be good
- Been thanked: 4881 times
- Ivan
- Has thanked: 3489 times
- Been thanked: 2267 times
Another day of the solar cycle is recorded in James's observations.
Ivan
Ivan
Even if through a very basic instrument. Today is cloudy so far. No breaks in the cloud deck.
- Has thanked: 20835 times
- Been thanked: 10504 times
Missed your reports James! Glad you got a view in with the sunoculars!
Good use of the Sunoculars James and hope your weather improves somewhat.
Had Thunderstorms forecast here today, but the Sun was clearly too hot to allow the clouds to form for that and https://www.blitzortung.org/en/live_lightning_maps.php
was watched in case the need to disconnect the radios to prevent further damage.
CLEAR SKIES
CLEAR SKIES
It's rained all evening here.
