24.07.2021 Between clouds
- Rusted
- Has thanked: 8172 times
- Been thanked: 1943 times
I am a martyr to clouds this morning but at least I could see the sun. [However briefly!]
The Baader 1.25x GPC is still just behind the PST etalon. It seems to help spread the goodness.
Three quick ones before it became impossible to focus properly. Mush + thermal agitation, then overcast.
800x800 frame size in SharpCap with the 2x TS GPC on the ASI174 camera nose. AS!3 + ImPPG + PhotoFilte7.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: 24.07.2021 Between clouds
Brilliant Rusted despite the clouds. I'm completely clouded out today, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Rusted
Thanks.Stardust5858 wrote: ↑Sat Jul 24, 2021 9:33 am Brilliant Rusted despite the clouds. I'm completely clouded out today, thanks for sharing.
It's been a real struggle to grab a 5 second gap.
I have added a later image from 11.51 after the sun showed itself again.
A bit more detail than earlier. Including some interesting, circular "curls" to the west.
- Has thanked: 9327 times
- Been thanked: 6163 times
These came out great, Chris ! Lots of good detail, a fabulous close up.
- MAURITS
- Has thanked: 2464 times
- Been thanked: 4881 times
- Been thanked: 4900 times
Excellent set of captures Chris - considering the cloud interruptions...
Thanks for sharing
Thanks for sharing
- Has thanked: 20822 times
- Been thanked: 10498 times
These came out well Chris!
- Been thanked: 8907 times
Wow!! these are really detailed and high res, you must be pleased with these
- Rusted
Thank you all for your encouragement.
The seeing conditions were so poor I could not judge best focus on the monitor. Just guesswork.
- Has thanked: 17855 times
- Been thanked: 17003 times
That's a great filament closeup!
- Been thanked: 4434 times
These turned out very well Chris...you managed to beat the seeing conditions with these. Nice work
- Been thanked: 4981 times
- Rusted
Thank you for your continuing support and encouragement.
Please send better seeing conditions ASAP!
- nicspenceryork
- Has thanked: 6087 times
- Been thanked: 1321 times
Wow! This is amazing! The detail you’ve caught is the stuff of dreams!
