24.07.2021 Between clouds
Rusted
Has thanked: 8127 times
Been thanked: 1943 times
Post by Rusted »
I am a martyr to clouds this morning but at least I could see the sun. [However briefly!]
The Baader 1.25x GPC is still just behind the PST etalon. It seems to help spread the goodness.
Three quick ones before it became impossible to focus properly. Mush + thermal agitation, then overcast.
800x800 frame size in SharpCap with the 2x TS GPC on the ASI174 camera nose. AS!3 + ImPPG + PhotoFilte7.
24.07.2021 10.14 1.25x 1.6x gpc.jpg (110.2 KiB) Viewed 337 times
24.07.2021 10.30 1.25x 1.6x gpc.jpg (131.3 KiB) Viewed 337 times
24.07.2021 10.39 1.25x 1.6x gpc.jpg (118.9 KiB) Viewed 337 times
24.07.2021 11.51 1.25x 1.6x gpc.jpg (127.45 KiB) Viewed 329 times
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Re: 24.07.2021 Between clouds
Post by Stardust5858 »
Brilliant Rusted despite the clouds. I'm completely clouded out today, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Rusted
Post by Rusted »
Stardust5858 wrote: Sat Jul 24, 2021 9:33 am Brilliant Rusted despite the clouds. I'm completely clouded out today, thanks for sharing.
Thanks. :bow
It's been a real struggle to grab a 5 second gap.
I have added a later image from 11.51 after the sun showed itself again.
A bit more detail than earlier. Including some interesting, circular "curls" to the west.
Has thanked: 9307 times
Been thanked: 6144 times
Post by ffellah »
These came out great, Chris ! Lots of good detail, a fabulous close up.
MAURITS
Has thanked: 2464 times
Been thanked: 4880 times
Post by MAURITS »
Excellent close-ups Chris.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Excellent set of captures Chris - considering the cloud interruptions...
Thanks for sharing
Has thanked: 20783 times
Been thanked: 10462 times
These came out well Chris!
Has thanked: 17970 times
Been thanked: 8905 times
Wow!! these are really detailed and high res, you must be pleased with these :bow :hamster:
Rusted
Post by Rusted »
Thank you all for your encouragement. :bow
The seeing conditions were so poor I could not judge best focus on the monitor. Just guesswork. ;)
Has thanked: 17845 times
Been thanked: 16977 times
Post by DeepSolar64 »
That's a great filament closeup!
Has thanked: 64 times
Been thanked: 4422 times
Post by MapleRidge »
These turned out very well Chris...you managed to beat the seeing conditions with these. Nice work :bow
eroel
Been thanked: 4971 times
Post by eroel »
Chris:
Beautiful images.
Well done even with clouds.
Rusted
Post by Rusted »
Thank you for your continuing support and encouragement. :bow
Please send better seeing conditions ASAP! ;)
nicspenceryork
Has thanked: 6034 times
Been thanked: 1310 times
Post by nicspenceryork »
Wow! This is amazing! The detail you’ve caught is the stuff of dreams!
