I hardly had time to set up my big gun before the clouds started to roll in this morning, so I had to be quick when the Sun reached my early morning observing spot on my driveway. I started by tweaking the collimation, which I think was a bit out after driving to Alexandra's and back the other day. When the Sun popped over my neighbours roof (not ideal for good seeing), I searched around for a suitable target. AR12847 came into view, so a quick focus and couple of SERs was all I could manage along with a flat field SER before everything 'turned south'. I hung around for about 30 minutes hoping for a decent gap, but to no avail and that was it for this session.
Anyhow, here's the result in mono and colour. Given the conditions it's a little soft and some of the fine structure has been missed.
20210725_Ha_RCT_AR12847_3ms_Mono by Stuart Green, on Flickr
20210725_Ha_RCT_AR12847_3ms_colour by Stuart Green, on Flickr
I hope you have better luck.
Thanks for looking.
AR12847 250RCT 25th July 2021
- Has thanked: 8544 times
- Been thanked: 8282 times
- Has thanked: 20783 times
- Been thanked: 10469 times
Re: AR12847 250RCT 25th July 2021
That turned out pretty good Stu. How often do you find you need to re-collimate the RCT?
- Has thanked: 9313 times
- Been thanked: 6146 times
Well done Stu on capturing some sun-light today, compared to S.E. not having much chance today.
- Been thanked: 8905 times
Hi Mark,marktownley wrote: ↑Sun Jul 25, 2021 8:36 am That turned out pretty good Stu. How often do you find you need to re-collimate the RCT?
I check the scope's collimation using my Takahashi Collimating Scope every time I use it. I find that it sometimes requires only a very minor tweak, but most often it doesn't need anything adjusting.
Many thanks, everyone. Looks like we're in for a spell of poor weather....thunderstorms today.
- VasilevIvan
- Has thanked: 399 times
- Been thanked: 266 times
Nevertheless, Stu, the volume of this sunny scene is very noticeable! Wish a lot of sunny days!
Best regards, Ivan.
VANTIM. Two Brothers observatory.
Observatory Dome 2.85m
SolarMax II 60mm DS, SW MAK 150, SW 80 ED, TS-Optics 6'' f5,9, LightBridge 12'' // AZ-EQ6 Pro, HEQ-5 mount
DayStar Quark Chromosphere, Lunt CaK B1800, D-ERF Baader 6'' // ZWO ASI 174mm, ASI 183mm, ASI178mm, ASI462mc, Player-One Apollo-M MAX.
