July 28 2021 White Light Extreme
- Has thanked: 1071 times
- Been thanked: 1985 times
Tested out the QHY5III 174M on white light and its a winner for sure!
5x & 2x Powermate 5x Powermate This is with the Esprit 150 and 2 barlows stacked with a bunch of other things
What's more interesting is that once i dialed in the shutter speed, the details just popped off, almost like I found some weird frequency with the atmosphere.
- Has thanked: 17581 times
- Been thanked: 16697 times
Re: July 28 2021 White Light Extreme
Excellent work Simon! There isn't much I like better than crisp clear granulation images and you have that here.
- Has thanked: 8418 times
- Been thanked: 8165 times
Excellent WL granulation shots, Simon.
- Rusted
- Has thanked: 8016 times
- Been thanked: 1938 times
Fascinating. What was this "magical" shutter speed?
Doubling up Barlows will pull the shutter speed right down.
Or demand far too much gain. Or both.
Excellent images BTW.
- Has thanked: 20442 times
- Been thanked: 10248 times
Yup, that works! Nice shots!
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4787 times
- Has thanked: 17672 times
- Been thanked: 8793 times
Thats what makes the QHY so interesting, when you up the gain, its not as noisy compared to the ZWO, and more importantly, the offset slide can be used to push the histogram off the left side.
How i found the magical shutter speed was to increase 1ms at a time. When I hit 20ms at that point, everything stopped moving. It was just plain weird. Sunday has predicted excellent seeing which is looking quite likely since there is a cool down. Were gonna get get clouded over today and tomorrow with high heat, normally, on the cool down trend here, seeing on the following day is good to excellent. I will test again and this time video the sequence.
- Been thanked: 4900 times
The "Porridge" is boiling so well Simon and you have certainly captured the action fabulously...
Well done
Well done
You just gave me a funny idea... i need to do a macro shot of sugar and see if it looks similar to the granulation, maybe that's why we called it granulation, as in granulated sugar??
EGRAY_OBSERVATORY wrote: ↑Thu Jul 29, 2021 10:22 pm The "Porridge" is boiling so well Simon and you have certainly captured the action fabulously...
Well done
That's a different way of looking for a comparison Simon, but for years I and others have used the term "porridge" and I don't think sugar would entice others to understand that when sugar boils, it would like the same as "granulated", compared to "porridge"..
- Has thanked: 146 times
- Been thanked: 277 times
So what’s up with the histogram slide in Firecapture? I have 2 ZWO cameras and don’t see any slide. But I do remember seeing it. Perhaps it was with a Basler I had.
I think ZWO cameras in general have the offset slide disabled for some reason, i dont remember why since it was a couple of years ago when they did it to certain cameras. It would make the horizontal banding really bad. Especially the 174, 224 and 120 cameras.
- Been thanked: 4340 times
Love those granulation details Simon
