Solar Harvest 3rd August 2021
- Has thanked: 8415 times
- Been thanked: 8161 times
A few from this morning in Ha and CaK.
First up Ca II K full disks
20210803_CaK_FD_mono by Stuart Green, on Flickr
20210803_CaK_FD_colour by Stuart Green, on Flickr
and a closer view of the newly named small active region AR12850
20210803_CaK2_AR12850_Mono by Stuart Green, on Flickr
20210803_CaK2_AR12850_colour by Stuart Green, on Flickr
Ha Full disks on my Lunt 60
20210803_Ha_FD_Mono by Stuart Green, on Flickr
20210803_Ha_FD_colour by Stuart Green, on Flickr
and a closer view of AR12850 and a small magnetically disturbed region.
20210803_Ha_AR12850 by Stuart Green, on Flickr
20210803_Ha_AR by Stuart Green, on Flickr
Some proms in the mix too.....
20210803_Ha_Proms1 by Stuart Green, on Flickr
20210803_Ha_Proms1_colour by Stuart Green, on Flickr
20210803_Ha_Proms2_Mono by Stuart Green, on Flickr
20210803_Ha_Proms2_colour by Stuart Green, on Flickr
The forecast isn't so good for the next few days, so that's probably it for a little while.
Thanks for looking.
Thanks for looking.
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
Re: Solar Harvest 3rd August 2021
Great set Stu
David
- Petrus
- Has thanked: 1496 times
- Been thanked: 684 times
Fantastic solar harvest Stu! I really enjoy images of those nice prominences.
~ Petrus ~
Flickr
Flickr
Thanks Stu for your excellent captures and you were lucky to have some clear skies that morning.
- Martin_S
- Has thanked: 979 times
- Been thanked: 2992 times
Wow, it looks like a bumper harvest Stu well done.
Martin
Martin
- Been thanked: 16693 times
These are really nice Stu. I especially like your CaK images.
Many thanks guys.
- Has thanked: 20435 times
- Been thanked: 10243 times
You got a very nice set of images there Stu, I was hoping for sun this morning, but, alas it is cloudy, maybe will clear up in a bit.
Hi Mark,
It’s brighter here, but really hazy. The outlook doesn’t look good.
Stu
Stu
- Has thanked: 9144 times
- Been thanked: 6025 times
Another excellent set, Stu. How do you keep the full disks so perfectly and evenly illuminated, if I may ask ?
- Has thanked: 6181 times
- Been thanked: 7142 times
- Has thanked: 3292 times
- Been thanked: 1887 times
When I first looked at the first proms you image I thought there was a thin arch connecting them.
The top low prom looked like a tiger with curved down tail and with some imagination the flare prom a ring master with whip.
Cheers. Andrew.
Cheers. Andrew.
- Been thanked: 4340 times
These are excellent images Stu...well done
- Been thanked: 4786 times
Hi Franco,
No secrets ... I spend quite a bit of time clocking and tuning the etalons, which when triple stacked gives me a bit of a headache. Sometimes everything just falls into place; other times I have to tweak and tweak and still I end up with slight unevenness. Sometimes I have to build from the bottom up.... No front etalons, just the internal pressure tuned etalon, which I get on band, then add the first external etalon and tweak and then add the second etalon and further tweak....and tweak again
The FD is a mosaic of multiple panes to try to even out any irregularities.
