Heads Up 4th August
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Heads Up 4th August
Hi all, just some screenshots of todays activity, the Sun seems to be a little quieter today. New plage area to the SE and AR2850 still showing spots. A few small proms particularly on the NW limb.
- Screenshot (302).png (885.13 KiB) Viewed 487 times
- Screenshot (303).png (612.61 KiB) Viewed 487 times
- Screenshot (304).png (911.56 KiB) Viewed 487 times
- Screenshot (308).png (618.84 KiB) Viewed 487 times
- Screenshot (307).png (1.16 MiB) Viewed 487 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Re: Heads Up 4th August
Thank you Ella for your latest captures, which yes, both the disk and proms are quiet today except for the S.W. AR2850.
As forecast from 0200hrs in my observatory, there is much high-thin cloud in our region, so will spend much of today processing 11+Gbytes of Saturn and Jupiter imagery taken last night with the newbie S/W ESPRIT scope instead...
Have a good day
Have a good day
- Been thanked: 10246 times
Thanks for the heads up Ella, just haze and towering clouds today for me, wouldn't surprise me if I get a heavy shower before nightfall.
- Been thanked: 4340 times
Thanks for the update Ella!!!
I imaged for a few hours this morning and will see how they turn out.
- Been thanked: 16694 times
Though I can see them visually in Ha, Your Ca II K images shows the plages/faculae better than I can see them visually, especially the disturbed areas between the two southern plages.
Thanks Ella!
Thanks Ella!
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Hi Nigella,
In recent days, the Sun is not very active. Your screenshots are still great. Thanks.
Ivan
Ivan
- Been thanked: 4787 times
- Stardust5858
Thanks Terry, not done any imaging for a few days, had to get worst of the eaves done before the rain. Great you've got some imaging done on Jupiter and Saturn.EGRAY_OBSERVATORY wrote: ↑Wed Aug 04, 2021 10:15 am Thank you Ella for your latest captures, which yes, both the disk and proms are quiet today except for the S.W. AR2850.
Have a good day
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Mark, I'm going to be clouded out and rain forecast for the next four days. Hopefully you'll get some better weather soon.marktownley wrote: ↑Wed Aug 04, 2021 4:26 pm Thanks for the heads up Ella, just haze and towering clouds today for me, wouldn't surprise me if I get a heavy shower before nightfall.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Brian, hopefully you've got some great captures.MapleRidge wrote: ↑Wed Aug 04, 2021 4:57 pm Thanks for the update Ella!!!
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks James, yeah, the plages showed up well in Ca II K. AR2850 was interesting in Ca II K as well.DeepSolar64 wrote: ↑Wed Aug 04, 2021 5:05 pm Though I can see them visually in Ha, Your Ca II K images shows the plages/faculae better than I can see them visually, especially the disturbed areas between the two southern plages.
Thanks Ella!
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Ivan, appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Maurits, appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Martin_S
- Has thanked: 979 times
- Been thanked: 2992 times
Hi Nigella, great captures, nothing but strong westerly winds down here in Brisbane, It's good to see that the UK is getting some clear skies.
I just wondered why you are using sidereal tracking and not solar?.
Martin
Martin
- Stardust5858
Thanks Martin, appreciated. I usually do do solar tracking, hadn't noticed that I forgot to change to solar tracking in my efforts to quickly grab a session, lol. You'll notice that I did on one screenshot. Sidereal is the default so I have to change that. If you know a way to make solar tracking my default I'd really appreciate that. Many thanks.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 8418 times
- Been thanked: 8163 times
Glad you managed to capture some images, Ella. A bit hit and miss at the moment here with the weather....one minute bright sunshine and the next it looks stormy!!
- Been thanked: 8791 times
Terrible weather here today, horizontal lashing rain since yesterday evening. Not much to do today but to stare at the water and hope it may stop. I guess this is why Ireland is green
- Stardust5858
Thanks Stu, not much chance of seeing the sun for me today either.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Rain here was well Alexandra, might get a chance tomorrow. Resumption of DIY after being ill will make processing several days away.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Martin_S
Martin
[/quote]
[/quote]
Hi Nigella, I'm not sure if there is a way to change the default settings for EQMOD as I'm quite new to it.
Martin
[/quote]
[/quote]
Martin
