I was hoping that AR2850 would unleash some extra action, but maybe that will occur on the far-side.
The S.E.AR appears very quiet, but a closer look does suggest that spots may emerge in due course.
Even proms are quite shallow...
CLEAR SKIES
4-8-2021 AR2850 STILL HAS FIVE-SPOTS..
- Been thanked: 4900 times
- 3-8-2021 0923z AR2850 latest_4096_HMII.jpg (86.78 KiB) Viewed 270 times
- 3-8-2021 0923z AR latest_4096_HMII.jpg (38.74 KiB) Viewed 270 times
- Has thanked: 9327 times
- Been thanked: 6163 times
- Has thanked: 20825 times
- Been thanked: 10499 times
Re: 4-8-2021 AR2850 STILL HAS FIVE-SPOTS..
Thanks Terry, looks like the spot is dying back a bit today...
- Been thanked: 4434 times
Thanks fro the update Terry.
- MAURITS
- Has thanked: 2464 times
- Been thanked: 4881 times
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Thanks Terry, similar to what I observed today.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Thanks Franco, Mark, Brian and Maurits.
Yes Mark - apparently down to 4-spots now, but the S.E.AR does have 1 and half spots !!
Also, it does look as if some action in both north and south regions will start to occur in 2/3-days, so all is not lost..
- 4-8-2021 1753 AR2850 latest_4096_HMII.jpg (26.39 KiB) Viewed 235 times
- 4-8-2021 1753 S.E.AR latest_4096_HMII.jpg (71.73 KiB) Viewed 235 times
- 4-8-2021 1805Z euvi_195_heliographic.jpg (44.95 KiB) Viewed 235 times
Thanks James.
Weather here quite good this afternoon and clear and cloudy skies, but was working on the mini-observatory bits before the build, so I still have to start processing last-night's Saturn and Jupiter captures...
Cheers
Cheers
Thank you Ella and also from the other-side as nicspenceryork, arnedanielsen, DeepSolar64, Montana...
CLEAR SKIES to you all.
