Sun in H-Alpha and CaK 25th of July 2021. Closeup of AR2847 and 80min timelapse
- Has thanked: 6305 times
- Been thanked: 7324 times
Dear friends,
Still trying to catch up...
Please find attached some images of the Sun in H-Alpha and CaK from July 25th pluss an 80 min timelapse of AR2847 and "the mustache filament".
FD image in H-Alpha using a Takahashi Sky-90II with Coronado 90mm/BF15, Coronado 2x CeMax and ASI 1600mm PRO. Sun FD in H-Alpha 25th of July 2021
FD image in CaK using a William Optics ZenithStar 61II stopped down to 46mm, Lunt CaK 1200 module, Coronado 2x CeMax and ASI 183mm camera Sun FD in CaK 25th of July 2021
Sun FD in CaK 25th of July 2021 - colorized
Close-up image of AR2847 and "the mustache filament" in H-Alpha using an Explore Scientific AR152, Baader 2" 35nm H-Alpha (as ERF), Daystar Quark H-Alpha Chromosphere and ASI ZWO 174mm camera. Sun in H-Alpha 25th of July 2021 - AR2847 and "mustache filament"
80 min timelapse of AR2847 and "the mustache filament" using the same equipment as above.
As usual click on links to view full size images.
Thanks for looking,
Arne
Thanks for looking,
Arne
Re: Sun in H-Alpha and CaK 25th of July 2021. Closeup of AR2847 and 80min timelapse
The close-up of the squigally filament is excellent Arne.
Thanks for sharing
Thanks for sharing
- rigel123
- Has thanked: 8576 times
- Been thanked: 8810 times
Great animation, wonderful details and love the sinuous movement in that large filament! Great job!
- Been thanked: 10489 times
These are great images Arne, love the closeup!
- Has thanked: 8559 times
- Been thanked: 8290 times
Very nice indeed, Arne.
Superb closeup view.
How do you find the ASI 1600mm PRO? Can you see/image the disk and proms at the same time (maybe if you adjust gamma)? I'm looking at purchasing one for myself (for use on my Lunt 60 + 2.5x PM FDs), but I'd be interested to know if the dynamic range is adequate. I can easily see both disk and proms on my Basler cameras without resorting to multiple exposures.
Thank you very much for your kind comments Terry, Warren, Mark and Stu.
Stu: I'm very happy with the ASI 1600mm Pro. I can certainly see both disc and prom features if I adjust gamma slightly. All my FD images with this setup (Sky-90II, Coronado 90mm frontfilter + BF 15, Coronado Cemax 2x) are single recordings with neutral gamma setting and processed to show both disc and prom details.
Please don't hesitate to ask if you would like to have access to some raw recordings or stacked (but not processed) images to help you with your decision process!
Arne
Arne
- Has thanked: 148 times
- Been thanked: 294 times
Arnie,
That Ha high res is spectacular. It really shows the potential of 150mmm
- Has thanked: 9319 times
- Been thanked: 6157 times
Fantastic mustache filament image and animation Arne. Congratulations on your eclipse image Sky & Telescope published in the September issue. Well done !
Thank you very much David and Franco.
I'm awaiting my copy of the September issue of S&T to arrive here in Norway.
Arne
Arne
Many thanks, Arne. Please could you send me a stacked image TIFF as a PM?arnedanielsen wrote: ↑Thu Aug 05, 2021 2:09 pm Thank you very much for your kind comments Terry, Warren, Mark and Stu.
Arne
Much appreciated.
Sent you an PM, Stu.
Arne
Arne
