Ha with 300mm Cassegrain in St Véran
Hello all, long time no see !
My new company has kept me very busy, and my new telescope was pretty late so all the solar stuff was on stand by.
Now I have received my new toy, it is a newton Cassegrain f/3.6-16 300mm from Skyvision with a zero dur primary.
It's very very good as expected from Michel Bonnin, and very smooth.
I wanted for a long time to test sub aperture ERF, one in front of the secondary taking most of the load, the other replacing the primary baffle to remove unwanted reflection of the main rejection.
I had a set of ERF coated for CaK and Ha, they are basically 80mm ERF made from fused silica.
That looks like this :
http://www.astrosurf.com/uploads/monthl ... e65a1.jpeg
http://www.astrosurf.com/uploads/monthl ... 832f7.jpeg
http://www.astrosurf.com/uploads/monthl ... 545b4.jpeg
http://www.astrosurf.com/uploads/monthl ... 817ff.jpeg
After testing in St Véran, it seems that the CaK version has an issue. Maybe a very small temp difference that just kills details like this, to be compared with Christian's images, Christian was standing 1,5m from me at that moment :
http://www.astrosurf.com/uploads/monthl ... 387ec5.png
But Ha do works. The coating is better for this one.
I used a PST etalon (the one Christian tested, the good one at less than 0,4A) Behind a 15mm blocker and a x2 power mate.
The Basler 1920 gave 0,12"/pixel, so remember that the features in the images below are pretty small !
http://www.astrosurf.com/uploads/monthl ... a39503.png
http://www.astrosurf.com/uploads/monthl ... 86232b.png
http://www.astrosurf.com/uploads/monthl ... 1d913d.png
http://www.astrosurf.com/uploads/monthl ... 0b6569.png
http://www.astrosurf.com/uploads/monthl ... 0fc996.png
http://www.astrosurf.com/uploads/monthl ... b35c0e.png
http://www.astrosurf.com/uploads/monthl ... c2f7c3.png
I quite happy with the results, and that could be extended to large apertures. 400mm seems pretty attainable.
Frédéric
Frédéric
Re: Ha with 300mm Cassegrain in St Véran
Not knowing what size all your images are Frédéric, it appears that unless they are JPEG's of 2-Mbytes (or less) they have not attached to your post.
Please try again as mentioned here by checking the format and sizes.
Thanks
Thanks
Thanks Terry !
Actually they are PNG, but hosted on Astrosurf. And it looks like the soft they use doesn't support links as images...
Here are the images in jpg !
- IMG_4592.thumb.jpeg.d1e773e9683d013c92025da67af3211d.jpg (882.84 KiB) Viewed 795 times
- IMG_4591.thumb.jpeg.34c7c474ccf839ee3632f6217d9e2e78.jpg (1.01 MiB) Viewed 795 times
- IMG_4590.thumb.jpeg.14b2d969c7a43efd2cc1f6c2c77c774b.jpg (1.06 MiB) Viewed 795 times
- IMG_4589.thumb.jpeg.9a20536a75b8f7675af4a18e77cdd34b.jpg (1.15 MiB) Viewed 795 times
- Wprom__2021-08-14_T_09-22-41-0669_L_lapl3_ap2607.jpg (386.5 KiB) Viewed 792 times
- Wprom__2021-08-14_T_09-16-57-0039_L_lapl3_ap2548.jpg (570.8 KiB) Viewed 792 times
- W_run3__2021-08-14_T_09-30-29-0388_L_lapl3_ap6009.jpg (1.15 MiB) Viewed 792 times
- W_run3__2021-08-14_T_09-26-33-0661_L_lapl3_ap6038.jpg (1.33 MiB) Viewed 792 times
- Wrun1_2021-08-14_T_09-08-06-0303_L_lapl3_ap5873.jpg (1.15 MiB) Viewed 789 times
- Wrun1__2021-08-14_T_09-02-26-0719_L_lapl3_ap5263.jpg (1015.23 KiB) Viewed 789 times
- Panorama.jpg (1.29 MiB) Viewed 789 times
- Has thanked: 1262 times
- Been thanked: 1057 times
Congrats, Frédéric! Great setup in the right place.
Amasing results!
thanks for sharing
Leo
Amasing results!
thanks for sharing
Leo
Thanks Frédéric and they are all well-shown on here too.
The Astrosurf image of the scope certainly are crystal-sharp when zoomed-in on my screen.
Thanks and for the images.
- Has thanked: 8415 times
- Been thanked: 8161 times
Great images Frédéric. Superb setup and enviable setting, there, high up in the mountains.
Stu
Stu
- Been thanked: 16693 times
WoW, what an impressive scope! And it certainly delivers.
- Has thanked: 17667 times
- Been thanked: 8788 times
WOW!!!! I think I would die and go to heaven with a CaK image like that through my C11 not perfect but good enough for me
Terrific set of images and I only wish I was there at St Veran
Terry, Astrosurf won't pay for a security certificate to be https, so the links are not supported by this forum for linking. If you click on the written link and open in a separate tab it works fine. Thanks Frédéric for uploading the JPEGS
- Been thanked: 4340 times
Amazing series of images Frédéric...very well done
- Been thanked: 4786 times
- Has thanked: 9144 times
- Been thanked: 6025 times
Congratulations on the new scope, Frederic, and the excellent images. Looking forward to your progress improving your scope and more beautiful results.
- Has thanked: 20424 times
- Been thanked: 10243 times
Good to see you here Fred and great images. I wonder if there is a bit of 'echo' of light between the 2 mirrored surfaces? were they tilted relative to each other?
