Session time is from 15:30 to 15:50 UTC. Intermittent. The skies are mostly cloudy with both low and high clouds. The seeing appears to be average or just below. The temperature is 73F ( 22.7C )
I can see three spots marking the location of AR12857 in the NW quadrant. Two bigger ones with a smaller pore in the center. The SDO HMIc 4K image shows two more in addition to this. The SDO HMIc 4K image shows several pores associated with AR12853 to the NW of AR12857 but I can't pick any of them up visually. High clouds my be hampering my efforts. I can softly make out some of the fine solar granulation today.
Though I did not observe in Ha I attached a GONG image to show users here the status of the large prominence on the NE limb.
I was lucky to get any kind of observation today.
August 16 2021 WL only
- Has thanked: 17949 times
- Been thanked: 17093 times
- Has thanked: 65 times
- Been thanked: 4455 times
Re: August 16 2021 WL only
Nice to see your post James
Too much cloud and too little time to consider trying anything today
Thanks James and you captured the one and only AR and as good as your attached SDO image..
Today was a quick view through and between clouds. I had no real time to study the sun. I was lucky to have gotten the views I did.
- Has thanked: 18090 times
- Been thanked: 8934 times
I'm glad you even got a glimpse James, that is worth more than anything else
Thanks for the virtual view
- Has thanked: 8588 times
- Been thanked: 8324 times
Many thanks, James. Just too cloudy for anything here.
- Has thanked: 2501 times
- Been thanked: 4924 times
Too cloudy here too. Thunderstorms and rain from tropical storm Fred!
- Ivan
- Has thanked: 3500 times
- Been thanked: 2285 times
Thank you for the interesting description, James. Even a quick glance through a telescope counts towards your task.
Ivan
Ivan
