New etalon, AR12858 and Prominences
- Has thanked: 300 times
- Been thanked: 312 times
I am now double stacking my Lunt 60mm THA/B1200CPT having received the new filter yesterday. A small break in the clouds turned up unexpectedly this afternoon and I set up to see how the ‘new’ view. Would welcome others thoughts on tuning the two etalons.....
I first got the exposure at 80% on this histogram and focussed the scope as a single stacked unit. Next I adjusted the pressure tuner until the histogram was at its lowest level.
Then I attached the second etalon to the front of the scope, refocused and adjusted the tilt until the histogram was at its highest point but not over exposed.
Sadly, I wasn’t helped by cloud cover regularly crossing my view whilst trying to dial everything in, but did manage to capture some images, the one below being the best of a poor bunch captured with the ZWO ASI 174mm and 3x Altair Astro Barlow ......
- AR12858 Proms & Filaprom_14_55_09Z_20210818_x3_Inv_.png (1.15 MiB) Viewed 466 times
Lunt 60mm DS TH⍺ B1200CPT.
ZWO ASI 174mm & tilt adapter.
SkyWatcher EQ6R-Pro.
SharpCap Pro.
Various Powermates and Barlows.
One cat with a love of tripod legs.
SharpCap Pro.
- Has thanked: 17853 times
- Been thanked: 16995 times
Re: New etalon, AR12858 and Prominences
Hughsie!
This is a beautiful capture of the filaprom in the NE!! I just observed it visually a short time ago.
- Rusted
- Has thanked: 8172 times
- Been thanked: 1943 times
Remarkably 3D!
- Has thanked: 9319 times
- Been thanked: 6157 times
Thank you James, I just read your report shortly after posting. Really enjoy your daily updates.DeepSolar64 wrote: ↑Wed Aug 18, 2021 5:39 pm Hughsie!
John
SharpCap Pro.
SharpCap Pro.
This is one of the best (if not the best) image with the Filaprom showing-up so very well that I've seen.
You not only have the perfect combination-settings of the two Etalons, to capture the proms and surface detail so well, which can be quite challenging to achieve with the LS-60 BF1200 DS-ing.
I am fairly certain that the large and big prominence that we have been seeing/imaging over the last 4-days or so, is that which has included the Filaprom in your image.
The image frame is also excellent...
Thanks for sharing
Thanks for sharing
- rigel123
- Has thanked: 8576 times
- Been thanked: 8810 times
Wonderful depiction of this prom, beautiful! Difficult to tell how well your tuning is unless we see an image that includes prom and surface without inverting one or the other. A well tuned DS will not show a double limb, but based upon your description it sounds like you should have it tuned fairly well. On my LS60T which is a tilt tune, I got the best tuning in SS as you did, and then after attaching the DS unit I only tilted the 2nd etalon enough to barely move the "ghost" image off of the disk.
Hughsie wrote: ↑Wed Aug 18, 2021 6:47 pmThank you James, I just read your report shortly after posting. Really enjoy your daily updates.DeepSolar64 wrote: ↑Wed Aug 18, 2021 5:39 pm Hughsie!
John
You are welcome and thank you!
I agree with Rigel
the image looks super and it sounds like you are doing it right
- Been thanked: 4427 times
Great shot John!!!
- Has thanked: 8559 times
- Been thanked: 8290 times
Excellent first light with your new DS filter. Nice.
- Has thanked: 6305 times
- Been thanked: 7324 times
