Dear friends,
Todays FD images in really poor seeing.
FD image in H-Alpha using a Takahashi Sky-90II with Coronado 90mm/BF15, Coronado 2x CeMax and ASI 1600mm PRO.
Sun FD in H-Alpha 19th of August 2021
FD image in CaK using a William Optics ZenithStar 61II stopped down to 46mm, Lunt CaK 1200 module, Coronado 2x CeMax and ASI 183mm camera.
Sun FD in CaK 19th of August 2021
Sun FD in CaK 19th of August 2021 - colorized
As usual click on links to view full size images.
Thanks and best regards,
Arne
Sun in H-Alpha and 19th of August 2021
- Has thanked: 6181 times
- Been thanked: 7142 times
Re: Sun in H-Alpha and 19th of August 2021
For a fairly bland disk Arne, you have certainly pulled-out the detail.
Thanks for sharing
Thanks for sharing
- Been thanked: 16691 times
Nice work Arne, I especially like the colored CaK one!
- Has thanked: 17667 times
- Been thanked: 8787 times
Bad seeing is better than no seeing Some great full discs Arne looks like some of those dreaded newtons rings creeping in to the top image
Thank you very much Terry, James and Alexandra!
Terry: The Sun is rather quiet... hope the activity will increase again soon.
Alexandra: I'm not sure why this is. The setup is permanently mounted and other than I refocusing (usually not necessary) I don't make any changes to the setup. I try to place the Sun in center each time and use the same method for taking flats. Still some hint of NR appears on some images and are gone on others.
And Yes, bad seeing is better than no seeing. :-)
Arne
Arne
