Hi!,
Out of 3 CaK sessions, this is probably the best image.
Alex
2021-08-19
T300 Solar newton
Baader FFC
CaK Filter
ASI290MM
Spots (without flare) in CaK with a T300
Re: Spots (without flare) in CaK with a T300
Thank you Alex and presumably this is the new AR in the S.E. which has eventually sprung these two spots and is now AR2860.
Excellent capture
Excellent capture
- Has thanked: 9145 times
- Been thanked: 6025 times
- Been thanked: 16694 times
WoW. Super high resolution here.
- Been thanked: 8791 times
- Been thanked: 4904 times
- Has thanked: 714 times
- Been thanked: 496 times
Thank you for the nice comments.
On the first one (The day I could capture the flare), the result was average.
On the next day, the seeing was poor (Or the collimation).
On the here session, the results were better.
CS
Alex
I made 3 CaK sessions with the same setup.another killer shot from St Veran
CS
Alex
- Has thanked: 6181 times
- Been thanked: 7142 times
Fantastic CaK image, Alex!
Thanks for sharing your amazing work!
Arne
Arne
- Been thanked: 4787 times
