Sun in H-Alpha and CaK 25th of August 2021
arnedanielsen
Has thanked: 6305 times
Been thanked: 7324 times
Post by arnedanielsen »
Dear friends,
It cleared just long enough in the afternoon for a set of FD in H-Alpha and CaK.
FD image in H-Alpha using a Takahashi Sky-90II with Coronado 90mm/BF15, Coronado 2x CeMax and ASI 1600mm PRO.
Sun90FD_143351_Ha_(Coronado_90mm_BF15)_20210825_ZWO ASI1600MM Pro_lapl4_ap5460_Sharpened_Contrast_resize.jpg
Sun90FD_143351_Ha_(Coronado_90mm_BF15)_20210825_ZWO ASI1600MM Pro_lapl4_ap5460_Sharpened_Contrast_resize.jpg (410.39 KiB) Viewed 287 times
Sun FD in H-Alpha 25th of August 2021
Huge faint prom on the SE limb
Sun90FD_143715_Ha_(Coronado_90mm_BF15)_20210825_ZWO ASI1600MM Pro_lapl4_ap377_Sharpened_Contrast_resize.jpg
Sun90FD_143715_Ha_(Coronado_90mm_BF15)_20210825_ZWO ASI1600MM Pro_lapl4_ap377_Sharpened_Contrast_resize.jpg (72.29 KiB) Viewed 287 times
Sun FD in H-Alpha 25th of August 2021 - prominence inverse
FD image in CaK using a William Optics ZenithStar 61II stopped down to 46mm, Lunt CaK 1200 module, Coronado 2x CeMax and ASI 183mm camera.
SunCaK60_142055_CaK_(3934nm)_20210825_ZWO ASI183MM_lapl4_ap7186_out_Contrast_resize.jpg
SunCaK60_142055_CaK_(3934nm)_20210825_ZWO ASI183MM_lapl4_ap7186_out_Contrast_resize.jpg (242.76 KiB) Viewed 287 times
Sun FD in CaK 25th of August 2021
SunCaK60_142055_CaK_(3934nm)_20210825_ZWO ASI183MM_lapl4_ap7186_out_Contrast_Colorized_resize.jpg
SunCaK60_142055_CaK_(3934nm)_20210825_ZWO ASI183MM_lapl4_ap7186_out_Contrast_Colorized_resize.jpg (260.35 KiB) Viewed 287 times
Sun FD in CaK 25th of August 2021 - colorized
As usual click on links to view full size images.
Thanks and best regards,
Arne
Arne
Has thanked: 17974 times
Been thanked: 8906 times
Re: Sun in H-Alpha and CaK 25th of August 2021
WOW!! look at that huge prom!! and the AR in the SE is coming along at amazing speed :bow :hamster:
MAURITS
Has thanked: 2464 times
Been thanked: 4880 times
Post by MAURITS »
Nice to see Arne.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Thanks Arne for sharing the images and with both the far north and far south proms is quite unusual.
arnedanielsen
Thanks for the kind comments, Alexandra, Maurits and Terry.
Arne
Arne
Ivan
Has thanked: 3483 times
Been thanked: 2263 times
Post by Ivan »
Nice work, Arne. The second photo is very original.
Ivan
arnedanielsen
Thank you very much, Ivan!
Arne
Arne
