Hα active regions and animation with RC8
GreatAttractor
Has thanked: 747 times
Been thanked: 753 times
Post by GreatAttractor »
Yesterday's results from the RC8/Aries ERF/Lunt 50 etalon setup (since I haven't sorted out the Blackfly-S yet, all shot with Chameleon 3 mono, ICX445). Seeing wasn't particularly good for this aperture, but I managed to capture a few stills and a short time lapse:
Animation of AR 2859, 30-second intervals, 48 minutes total:
My software:
My images
Has thanked: 17672 times
Been thanked: 8793 times
Re: Hα active regions and animation with RC8
I know the seeing wasn't great but the animation is fabulous!! well done, it is amazing how much jiggles around on the Sun over a short timescale.
:movie
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Good effort under the weather conditions
Ivan
Has thanked: 3465 times
Been thanked: 2250 times
Post by Ivan »
Nice animation, Filip. What was the visibility?
Ivan
GreatAttractor
Thank you, everyone.
Ivan: good air transparency, fast low clouds from time to time. The seeing situation seemed similar to my previous session in May, the conditions were best for 60-90 minutes early in the morning (once the Sun has reached 25-30° altitude), i.e. sub-second values on the SSM for even 10 s at a time. Then it worsened, with only occasional glimpses of fine details. Could be a pattern for this location. I hope higher-fps capture (once I have a tilter for the BF-S) can help with this somewhat.
My software:
My images
MAURITS
Has thanked: 2412 times
Been thanked: 4787 times
Post by MAURITS »
Nice to see Filip.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
H-Alpha
Has thanked: 1674 times
Been thanked: 982 times
Post by H-Alpha »
Hi Filip,
Can you please describe how do you manage to adapt and connect your Lunt etalon with your C8?
Alexandros
Alexandros
Greece
GreatAttractor
Here you go: link.
My software:
My images
