Dear friends,
Over the Summer I have mostly been imaging from my backyard observatory. This allows me to keep everything setup and ready to imaging in just a few minutes. Unfortunately my old trusty Pier-Tech 2 Pier died on me the other day and combined with the Sun starting to get very low on the sky this limits my imaging-window from the observatory to just a couple of hours. This imaging window is shrinking rapidly and I will have to move back to using my portable setup.
Anyway, here are a couple of FD images from the observatory (probably the last for this season) and a couple with the portable setup.
FD image in H-Alpha using a Takahashi Sky-90II with Coronado 90mm/BF15 w/Beloptik ITF, Coronado 2x CeMax and ASI 1600mm PRO everything mounted on a Paramount ME.
Sun FD in H-Alpha 29th of August 2021
FD image in H-Alpha using a Coronado 60mm/BF15 w/Beloptik ITF, Baader 35nm H-Alpha and ASI 178mm everything mounted on a SkyWatcher SolarQuest.
FD image in H-Alpha using a Coronado 60mm/BF15 w/Beloptik ITF, Baader 35nm H-Alpha, Coronado 2x CeMax and ASI 183mm everything mounted on a SkyWatcher SolarQuest.
FD image in CaK using a William Optics ZenithStar 61II stopped down to 46mm, Lunt CaK 1200 module, Coronado 2x CeMax and ASI 183mm camera everything mounted on a Paramount ME.
Sun FD in CaK 29th of August 2021
Sun FD in CaK 29th of August 2021 - colorized
As usual click on links to view full size images.
Thanks and best regards,
Arne
Sun FD in H-Alpha and CaK 29th of August 2021
- Has thanked: 6305 times
- Been thanked: 7327 times
- Has thanked: 8559 times
- Been thanked: 8297 times
Re: Sun FD in H-Alpha and CaK 29th of August 2021
Sorry to hear about your troubles, Arne. Hopefully you can get it fixed.
Nice images.
Nice images.
- Rusted
- Has thanked: 8172 times
- Been thanked: 1943 times
Can't the Pier-Tech be repaired? It seems like a hideously expensive item to have a break down.
I know nothing about the mechanism. Nor what might be the problem.
The hive mind of the forum system might be able to suggest a way forwards.
- Been thanked: 8907 times
These are stunning images Arne, you have had a really good run this summer getting much more sunshine than the UK but sorry to hear about the mount, at least you have the whole of the winter to try and fix it, I hope it can be repaired?
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Wonderful images!
Marios S.Ioannou
Sketcher/Visual Observer
Thank you very much for all your kind comments.
The warranty period is long gone for the pier (I’ve had it for 15 years) and trying to fix it means removing everything mounted on it. I will then lose my polar-alignment, T-Point model etc. I don’t think I will bother to mess around with that now and instead live with as it is. For deep sky imaging I’m mainly using it in the position it is now to protect the scope as much as possible from local light pollution and wind. The only times I raise the pier is for solar imaging and when there is something interesting (like a comet) low on the horizon.
Alexandra: Luckily it’s just the pier. The weather have been unusually good here in the Southern parts of Norway this Summer and combined with home-office (due to Covid) and staying home for the vacation have allowed me to do lot of Solar imaging.
Arne
Arne
