Hi everyone...
Just following up on the session form Friday, this is the set of images taken yesterday (Sept 4th). The same equipment was used for the full disk and closeups that I listed in the post with the Friday images.
The full disk shows the new areas of activity are continuing to develop:
The NW quadrant still has AR2861 and the filaments showing:
AR2863 is still prominent in the mid south latitudes:
The new AR's in the SE were recently named AR2888:
The newly emerged AR's in the NE were also names AR2864/2865, with a large filament to the north:
The proms continued to put on a good show as well:
That is all I have processed so far, but I did get some images with the 4x Powermate after the clouds thinned out. I will post if they process out nicely.
September 4th - Ha Set
- Been thanked: 4340 times
- Been thanked: 4786 times
- Been thanked: 16691 times
Re: September 4th - Ha Set
Wonderful work Brian. Your images show so much more than I can see!
- Has thanked: 6181 times
- Been thanked: 7142 times
Maurits, James, and Arne...
Thanks for all of the comments and feedback on the images guys...very much appreciated
James, you're not alone, I can't see that level of detail either My eyes are getting old and being type 1 diabetic most of of my life doesn't help either!
- Has thanked: 9144 times
- Been thanked: 6025 times
Beautifully done, Brian. You captured those large proms in great detail together with all other main features of the sun.
Thanks for your feedback Franco...always appreciated
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Very nice images!
Marios S.Ioannou
Sketcher/Visual Observer
- Has thanked: 20424 times
- Been thanked: 10243 times
You got a good run of images there Brian!
