FDs and prom animations 15th Sept 2021
- Has thanked: 8415 times
- Been thanked: 8161 times
A beautiful morning after some early morning mist/fog lifted and an opportunity to make a couple of short prom animations. Things are really quiet and even the proms showed little movement over 15-20 minute timespans.
First up the FDs in CaK and Ha.
20210915_CaK_FD_Mono by Stuart Green, on Flickr
20210915_CaK_FD_Colour by Stuart Green, on Flickr
Ha mosaic with a few 'witness' lines along some of the joins
20210915_Ha_FD_Mono by Stuart Green, on Flickr
20210915_Ha_FD_Colour by Stuart Green, on Flickr
Animated small prom and departing active region.
20210915_Ha_Prom_Animation_aligned by Stuart Green, on Flickr
...and a little prom forest with some subtle movements close to the limb.
20210915_Ha_Prom2_Animation_Aligned by Stuart Green, on Flickr
20210915_Ha_White Proms_Mono by Stuart Green, on Flickr
20210915_Ha_White Proms_Colour by Stuart Green, on Flickr
In addition, here's a three pane mosaic of a random piece of the chromosphere.
20210915_Ha_Chromosphere_Mono by Stuart Green, on Flickr
Thanks for looking.
Thanks for looking.
- AJamesB
- Has thanked: 1150 times
- Been thanked: 630 times
Re: FDs and prom animations 15th Sept 2021
Beautiful hi-res work, love it!
Lunt ls100tha single stacked + hinode solar guider on ioptron cem26 mount
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
A great job with the excellent images and animations and at least makes up for just the one AR.
Thanks Stu.
Thanks Stu.
- Has thanked: 146 times
- Been thanked: 277 times
Stuart.
Your last 3 images are stunning. The mosaic is just so rich detailed and shows a subtle hand at bringing out contrast. Your processing of the Ha images of the proms is fantastic. Any words of advice on how you achieve your jet black background and gorgeous luminescence of the prominences ?
- Has thanked: 17572 times
- Been thanked: 16691 times
WoW, Stuart. You are an ace at this imaging stuff. All of these are so good it's hard to pick a favorite. You certainly had the sun well documented today and did it beautifully.
Three thumbs up!!! WooHoo!!!
- Has thanked: 2412 times
- Been thanked: 4786 times
- Radon86
- Has thanked: 745 times
- Been thanked: 660 times
Hi Stuart (Carbon60),
Outstanding work Stuart !
How did you align the images ? DId you use ImPPG ? I would be grateful if you could point me to a tutorial on aligning images for Prom animations ?
Many thanks.
Magnus
Many thanks.
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- Has thanked: 17666 times
- Been thanked: 8787 times
Wow!! what a set Stuart I love the hedgerow prom looks like we are just about to lose all the great activity though.
Hi David,DavidP wrote: ↑Thu Sep 16, 2021 2:21 am Stuart.
This is a combination image (proms and disk processed separately). This allows the proms to be processed so that they 'pop' by boosting the contrast.
Hi Magnus,
I use ImPPG to align the images. If you head to the library section you'll see some tutorials on how to make animations, including one from me.
viewtopic.php?f=7&t=28572
I hope this helps.
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Excellent work!
Marios S.Ioannou
Sketcher/Visual Observer
- Has thanked: 20424 times
- Been thanked: 10243 times
Looking good Stu! I was thinking you would be imaging when the sun was out earlier...
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
- rigel123
- Has thanked: 8310 times
- Been thanked: 8537 times
Excellent Stu, the images and animations are top notch!
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
Many thanks, Arne and Warren.
Stu
Stu
- Has thanked: 9144 times
- Been thanked: 6025 times
Many thanks, Franco.
