10.09 BST Sunny Breeze Haze
35nm KG3 25mm Clave'
Prom group up from 2.00:
Two small spikes below leaning down.
Column with triangle top leaning up.
Little spike.
3 proms - Coumn with spray up, Banyan tree, little column top leaning up
Eiffel Tower prom.
3 faint sprays
5.30 Little spike
10.00 Fuzzy prom leaning up. Row of filaments under.
7.30 Spotted pyramid
4.30 Arch with broad bases.
Mottling.
Cheers. Andrew.
90mm Triplet with 4.2x barlow and Quark Chromo
- Has thanked: 3322 times
- Been thanked: 1907 times
Re: 90mm Triplet with 4.2x barlow and Quark Chromo
And at 11.00 with the Quark Prominence --:
Little spike.
Eiffel Tower prom.
3 faint sprays
Cedar tree with bar across leaning up. Pointy top leaning down.
Column with X shape on top of top side.
Culumn with extensions back to the X shape.
Black space.Fuzy [rom leaning up.
Then fuzzy longer spike leaning up.
Gap.
Column prom with spray top. Spike halfway up pointing up.
Big fuzzy prom with hollow base. Spray from top leaning down.
Slight gap the lower hedge prom sloping down as goes away.
5.30 Little spike
Triple feed prom leaning up.
Small pyramid
Faint hollow prom
Little spike leaning up.
Cheers. Andrew.
Little spike.
Eiffel Tower prom.
3 faint sprays
Gap.
5.30 Little spike
Small pyramid
Faint hollow prom
Cheers. Andrew.
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
I thought the Quark chromo already was a barlow of 4.2x.
Are you using a barlow 4.2x with your eyepiece ??
Thanks.
Magnus
Thanks.
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- Has thanked: 18062 times
- Been thanked: 8920 times
Fantastic description of the day Andy, thanks for this
I have a Prominence and a Chromosphere Quark. One was a 4.2x and one a Combo. My engineer got the lock screws out so I can use them in either mode.
So I can use them with the 4.2x or other barlows I have.
Cheers. Andrew.
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Lovely!
Marios S.Ioannou
Sketcher/Visual Observer
- Has thanked: 20908 times
- Been thanked: 10567 times
Thanks for the report Andrew glad the sun was shining for you.
