Mostly cloudy but gaps and a light breeze.
90mm F6.7 UV-IR 4.2x Chromo Quark Clave' 25mm
Around 1.00 BST Mostly cloudy, light wind with small clear patches.
I could see the prom at 8.30 on Learmonth Gong. Thin top pointing towards the big group arond 7.00
A little wedge prom on the surface next to it rising away.
A little hollowish prom. Little prom with arch going over it. At the other end a little pyramid prom.
There were two tiny proms from the hollow prom then two larger ones.
Over the hollow prom there were two small bright lines, arched slightly down.
Over the two larger proms there were proms going up, with a gap before a small dot above then.
There was another bright dot between the dot and the top line.
Faint lines continuing from the two bright ones.
The whole area seemed to be a fine tracery.
I could see a tiny prom and then a group of 3 up from the 8.30 prom. Thin prom leaning down with bright dot at the top with tiny prom under it and then a small stubby prom.
A small filament visible above the hollow prom, and a fainter one above it. Mottling seen.
Cheers. Andrew.
90mm Triplet with 4.2x barlow and Quark Chromo
- Has thanked: 3315 times
- Been thanked: 1907 times
- Has thanked: 20783 times
- Been thanked: 10467 times
Re: 90mm Triplet with 4.2x barlow and Quark Chromo
Nice report, thanks Andrew. I saw a plane transit this morning while looking at el sol through the DS90, it was a pleasant surprise to see 'live'.
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Very nice report Andrew
Marios S.Ioannou
Sketcher/Visual Observer
- Been thanked: 8905 times
Glad you got a clear spell to see the Sun yesterday Andy and thanks for the report. The Sun was too fleeting in between weather fronts for me to risk setting up
