AR2871 and other - September 25, 2021
- Has thanked: 9307 times
- Been thanked: 6144 times
Hello all: today a splendid day with good seeing. I had time to enjoy AR2871 in Ha and Sodium, plus a tall prom was giving a good show. I loved the complexity of this active region ! The plasma very much looks like art, in my opinion. I wish we had more days like this, the seeing was good, it was a good solar session. HaT203mm scope with SS for Ha, 6" Explore Scientific with sodium quark for sodium.
I hope you had a chance to image this very interesting active region.
- 090641 AR2871 mono.jpg (775.31 KiB) Viewed 432 times
- 090641 AR2871 inverted.jpg (836.97 KiB) Viewed 432 times
- 090641 AR2871 color.jpg (1.13 MiB) Viewed 432 times
- 090008 AR2871 inverted.jpg (970.47 KiB) Viewed 432 times
- 090008 AR2871 lighter.jpg (915.05 KiB) Viewed 432 times
- 092721 AR2871 wide field inverted.jpg (760.41 KiB) Viewed 432 times
- 092721 AR2871 wide field mono.jpg (777.24 KiB) Viewed 432 times
- 110706 AR2871 sodium color.jpg (1.93 MiB) Viewed 432 times
- 110706 AR2871 sodium mono.jpg (1.44 MiB) Viewed 432 times
- 104659 AR2871 wide field sodium color.jpg (1.05 MiB) Viewed 432 times
- 104659 AR2871 wide field sodium mono.jpg (775.35 KiB) Viewed 432 times
- 093622 tall prom color.jpg (451.7 KiB) Viewed 432 times
- 093622 tall prom mono.jpg (89.06 KiB) Viewed 432 times
- HaT203mm.jpg (1.81 MiB) Viewed 432 times
- Exp Sc 152mm.jpg (1.82 MiB) Viewed 432 times
- Has thanked: 20783 times
- Been thanked: 10467 times
Re: AR2871 and other - September 25, 2021
Thats a very good set of images there Franco, and nice to see pics of the setup too.
- Been thanked: 8905 times
- rigel123
- Has thanked: 8566 times
- Been thanked: 8800 times
Excellent! The resolution is wonderful!
- Ivan
- Has thanked: 3479 times
- Been thanked: 2260 times
Franco, these are amazing photos! So clean, clear, detailed, I looked at them with great pleasure. Congratulations on the spod! Your setup looks great.
Ivan
Ivan
Thank you Warren and Ivan for your kind words. I admire your solar work: you both put great passion in it.
- Been thanked: 4971 times
Franco:
A super set of images and also beautiful setups.
Thanks for sharing my friend.
- Has thanked: 8544 times
- Been thanked: 8280 times
Superb images, Franco. I’d say the best you’ve ever produced. Just shows how critical good seeing is at these image scales with larger scopes.
Thank you Eric, Stu and Maurits for the positive comments. Stu: seeing is obviously critical but I think I learned a tip that is leading to better results by watching Emil’s video on Autostakkert. This new mount also tracks the sun much better: I really like it.
Care to elaborate Franco?
Sure Mark. This may or may not be new to other solarchatters, but it is new to me. Instead of stacking a certain more or less fixed and arbitrary percentage of frames, say 10 to 25% as I usually did, I followed Emil’s advice of stacking all frames that are above the 50% threshold in the quality analysis graph. This means a totally different percentage for each image each time. In my recent 1000 frames ser files it meant anywhere between a low of 70 to a high of 750 frames to be stacked. It seems to work for me. Hope it works for some of our members too.
- Been thanked: 4423 times
Superb images Franco...excellent work
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Fantastic images!
Marios S.Ioannou
Sketcher/Visual Observer
- Has thanked: 6296 times
- Been thanked: 7311 times
Fantastic collection of images, Franco!
Love the two setups as well.
Arne
Arne
