Captures from 26th September
- Rob63
- Has thanked: 573 times
- Been thanked: 591 times
Thanks for all the welcomes, some of you will know me from SGL but I am finally brave enough to stop "lurking" and post some stuff here.
I have decided after years of frustration with the weather to minimise my DSO imaging and concentrate on Solar and Lunar work.
I am finally getting through the data I captured this weekend (220Gb), I wasn't expecting too much as, while the seeing was good, it was very windy.
Quite happy with the results though. (N.B, I have rotated images to give a more pleasing presentation rather than the actual position)
All images captured using ED120MM on an EQ6-R
Ha: ASI174MM with Quark (Chromo) + Baader 35nm as EFF
WL: ASI290MM + 3x TV Barlow + Lunt wedge + Baader Continuum filter
AR2871 AR2871 3-panel (2 good, 1 not so good) AR2872 Sunspot (AR2871)
Quark Chromosphere, Lunt LS60MT DS, Lunt Ca-K B1200 module, Baader herschel wedge
Sky-Watcher ED120 & ED80, StellaLyra 8" CC
Sky-Watcher EQ6R-Pro, ZWO AM5
ZWO ASI120MM, ASI174MM, ASI290MM, ASI1600MM
- Been thanked: 4787 times
- Has thanked: 9149 times
- Been thanked: 6027 times
Re: Captures from 26th September
Well done Rob for showing us your excellent captures.
Thanks for sharing
Thanks for sharing
- Has thanked: 6181 times
- Been thanked: 7142 times
- Been thanked: 8794 times
- Been thanked: 10248 times
You got some nice shots there Rob!
- Radon86
- Has thanked: 745 times
- Been thanked: 660 times
Hi Rob,Rob63 wrote: ↑Thu Sep 30, 2021 7:52 am Thanks for all the welcomes, some of you will know me from SGL but I am finally brave enough to stop "lurking" and post some stuff here.
Great work, lovely images !
1) I was wondering if your Baader 35nm H-alpha filter is really enough for 120mm scope ? as an energy rejection filter. I suppose the sun low down and in winter is less dangerous than when its hot and high up in the sky ?
2) What 120mm ED scope do you have ?
Good luck with your imaging.
Thanks,
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Beautiful images!
Marios S.Ioannou
Sketcher/Visual Observer
- Rob63
Hi Magnus,Boso36 wrote: ↑Fri Oct 01, 2021 10:41 am Hi Rob,
Thanks,
Magnus
Re 1) I am using a 'straight through' setup and the 2" filter is at the end of a long extension tube so it's a fair distance from the quark.
I have tested the temperature at the camera end of the filter and it is not hot even after an hour. I have been using this setup for four years without problems. I am actually planning to get an external ERF when Baader get them back in stock as I also want to get a Flir Grasshopper (again out of stock for now).
I switched to the 35nm from a UV/IR after reading this thread viewtopic.php?f=9&t=31763
2) It's the Sky-watcher 120ED DS-Pro 900mm f7.5 (f31.5 with the quark)
Cheers,
Rob.
- Has thanked: 8418 times
- Been thanked: 8165 times
Welcome to the light…..
Excellent debut images, Rob.
- Been thanked: 4340 times
Great image Rob...nice work
- Been thanked: 4904 times
