Monday Sun 4th October 2021
- Has thanked: 8418 times
- Been thanked: 8165 times
A brief period of sunshine midday gave me an opportunity to take a few images in Ha, Ca II K and 430nm.
First up is a Ca II K FD in mono and colour showing some nice plage banded regions in the northern and southern hemispheres, punctuated with two active regions: AR12880 towards the meridian and AR12882 just this side of the eastern limb.
20211004_CaK_FD_Mono by Stuart Green, on Flickr
20211004_CaK_FD_colour by Stuart Green, on Flickr
.... and here in Ha.
20211004_Ha_FD_Mono by Stuart Green, on Flickr
20211004_Ha_FD_colour by Stuart Green, on Flickr
The seeing conditions were quite okay for the most part and I managed to capture some closer views of the active region AR12882 using my Lacerta solar wedge on my Tecnosky 125 with 2.5x and 5x PMs respectively, although it was a struggle to retain much detail at the higher magnification. I've cropped the original a little as well with this image. The 'Wilson' effect is clear to see (a slight depression within the umbra causing the closest edge of the penumbra to appear thinner than the rest of it).
20211004_AR2882_430nm_x2.5 by Stuart Green, on Flickr
20211004_AR2882_430nm_x5 by Stuart Green, on Flickr
AR12880 appears a just a few minor sunspots and pores currently.
20211004_AR2880_430nm by Stuart Green, on Flickr
By this time I could see clouds rolling in from the west, thick and very dark, causing me to panic a little and pack up before we received one of the many heavy showers we've been having recently and that was the end of the session for today.
Thanks for looking.
Thanks for looking.
The seeing conditions were quite okay for the most part and I managed to capture some closer views of the active region AR12882 using my Lacerta solar wedge fitted with a 430nm filter on my Tecnosky 125 with 2.5x and 5x PMs respectively, although it was a struggle to retain much detail at the higher magnification. I've cropped the original a little as well with this image. The 'Wilson' effect is clear to see (a slight depression within the umbra causing the closest edge of the penumbra to appear thinner than the rest of it).
Thanks for looking.
Thanks for looking.
- Has thanked: 6181 times
- Been thanked: 7142 times
- Has thanked: 9149 times
- Been thanked: 6027 times
- rigel123
- Has thanked: 8319 times
- Been thanked: 8545 times
Re: Monday Sun 4th October 2021
Wonderful shots Stu, and love that closeup of AR2882!
- Has thanked: 17581 times
- Been thanked: 16698 times
These are beautiful Stuart! Thanks for the views. I have been largely clouded out today.
- Been thanked: 8794 times
Terrific images Stuart, the white light view is my favourite, it's lovely to see the Wilson effect
- Been thanked: 10248 times
These are excellent Stu, the WL is very good indeed.
- Been thanked: 4787 times
Many thanks, everyone.
Apologies for the duplicate post originally.
