Oct. 9th 2021 AR12882 Ha and WL
Astrophil
Been thanked: 581 times
Post by Astrophil »
Hi All,
Beautiful activity on the sun today. Unfortunately only enough blue sky to grab the little Mak for a quick session. A little sun is better than none.
The Ha images were taken using a Solar Spectrum filter attached to a Questar 3.5". The continuum was with a 540nm filter.
Phil
arnedanielsen
Has thanked: 6276 times
Been thanked: 7296 times
Re: Oct. 9th 2021 AR12882 Ha and WL
Post by arnedanielsen »
Excellent images, Phil!
Arne
Arne
AstroBin: https://www.astrobin.com/users/arnedani/
Has thanked: 8523 times
Been thanked: 8258 times
Very nice, Phil.
Has thanked: 9298 times
Been thanked: 6133 times
Post by ffellah »
Beautiful sharp, with contrast images, Phil. Nice to see you back !
MAURITS
Has thanked: 2463 times
Been thanked: 4879 times
Post by MAURITS »
Excellent captures Phil.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 17925 times
Been thanked: 8894 times
What incredible beauty :bow :hamster:
Astrophil
Post by Astrophil »
Thanks for the kind comments. It has been quite a while since I posted any images here. During my last outing with the larger scope I twisted my back and have been a little reluctant to lug it out for a while longer at least. The smaller scopes get to see the sun now.
The little Questar is lightweight but has a limit as to the weight of equipment that can be attached and still balance and track. Usually the Quark is used because it’s light but for these images the Solar Spectrum was tested on it. The images were better than the Quark but tracking was iffy at times. It sure would be nice if there was a lighter weight Solar Spectrum filter.
Phil
Has thanked: 20756 times
Been thanked: 10442 times
Very nice detail in these shots Phil!
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Great details recorded in these images Phil :bow
Impressive for the smaller aperture!!!
Has thanked: 17813 times
Been thanked: 16953 times
Post by DeepSolar64 »
As usual I notice the white light detail first. Nice job!
