Holiday Monday - Ha Sun
- Has thanked: 65 times
- Been thanked: 4462 times
Hi all...
I had a break form the clouds and work on Monday this week (Canadian Thanksgiving), and had a chance top do some imaging before lunch. It was close to two weeks since the last solar session, and I was glad to see that that AR2882 was still going strong and there were several proms and filaments to view as well. The seeing was average at best and the live views on the computer screen seemed to have a high frequency vibration appearance, but the stacked images don't appear to be too bad. The contrast across the mosaics is not the best due to the variable conditions.
The first image from the session is the full disk composite through the LS80T/LS75FHa/B1800Ha solar scope and the ASI1600MM camera with a 1.3x barlow: The image below is a longer exposure of the limb showing some of the fainter proms on the eastern limb and the arcs between the brighter proms on the western limb: The remainder of the images were all captured with the double stack modded Orion EON 130ED OTA fitted with a pair of Lunt DSII etalons and the B1800 blocker. Image capture with the ASI290MM and a 1.6x barlow. First is the most prominent feature, AR2882, and AR2882 nearing the NW limb: AR2884 was placed along with several other active areas and filaments, which spread across the southern part of the disk: The final disk image shows a small regions starting to appear on the eastern limb: The final images were of the proms...a few are a bit grainy, but the longer exposures were more influenced by the seeing and some thin cirrus cloud had started to build at this time too: That was all I managed to capture on Monday, and spent the rest of the day recovering from two Thanksgiving diners, and working on the new observatory (pics to come )
- Has thanked: 17969 times
- Been thanked: 17112 times
Re: Holiday Monday - Ha Sun
WoW Brian, that was a nice filaprom! I was clouded out on that day you captured that nice U shaped filament. Nice capture!
- Ivan
- Has thanked: 3500 times
- Been thanked: 2285 times
Brian, lovely set! The close-ups through the double stack are stunningly beautiful.
Ivan
Ivan
- Has thanked: 2501 times
- Been thanked: 4928 times
I agree with the previous commentators Brian.
Beautiful captures showing such fine detail of Monday.
Thanks for sharing
Thanks for sharing
- Has thanked: 6353 times
- Been thanked: 7411 times
James, Ivan, Maurits, Terry, and Arne...
Thanks fro all the kind words and feedback on the session. Very much appreciated
- Has thanked: 9387 times
- Been thanked: 6201 times
Thanks Franco
It was great to get some time at the scope after missing out the previous 2 weeks.
- Been thanked: 5016 times
Thanks Eric
The weather doesn't sound very favorable to getting any sun till the middle of next week...will watch whats going on among the posts here!
- Has thanked: 8596 times
- Been thanked: 8327 times
Glad you managed to get some Sun time, Brian, with excellent results.
- Has thanked: 18105 times
- Been thanked: 8942 times
What a lovely solar harvest Brian and I hope you enjoyed the two feasts I really love the filaprom Happy Thanksgiving
Stuart and Alexandra...
Thank you for your comments and feedback on the images...always appreciated
Hard to believe it has been a week since the holiday Still a few left overs to get finished off.
- Has thanked: 20962 times
- Been thanked: 10597 times
Lovely shots Brian, hope you and the family had a good thanksgiving holiday.
