Dear friends,
Todays FD images of the Sun in H-Alpha and CaK.
FD image in H-Alpha using a Coronado 60mm/BF15 w/Beloptik ITF, stopped down to 50mm, Baader 35nm H-Alpha and ASI 178mm mounted on a Celestron NexStar SE mount.
Sun FD in H-Alpha 15th of October 2021
Sun FD in H-Alpha 15th of October 2021 - Colorized
FD image in CaK using a William Optics ZenithStar 61II, stopped down to 46mm, Lunt CaK 1200 module, Coronado 2x CeMax and ASI 183mm camera mounted on a SkyWatcher SolarQuest.
Sun FD in CaK 15th of October 2021
Sun FD in CaK 15th of October 2021 - Colorized
Click on links to view full size images.
Thanks for looking and best regards,
Arne
Sun FD in H-Alpha and CaK 15th of October 2021
- arnedanielsen
- Has thanked: 6305 times
- Been thanked: 7322 times
- Has thanked: 17849 times
- Been thanked: 16992 times
Re: Sun FD in H-Alpha and CaK 15th of October 2021
These are excellent processed full discs, Arne! I think the sun is calming down a bit.
- Been thanked: 4427 times
Very sharp images Arne...thanks for sharing them
- Has thanked: 8558 times
- Been thanked: 8290 times
Beautiful FDs, Arne.
- arnedanielsen
Thank you very much James, Brian and Stu!
James: Yeah, the Sun is turning almost blank. Hope there will be some new AR shortly.
Arne
Arne
- Has thanked: 2464 times
- Been thanked: 4880 times
- arnedanielsen
- Has thanked: 20813 times
- Been thanked: 10484 times
Great disks as ever Arne!
- arnedanielsen
Thank you very much Mark. Much appreciated.
Arne
Arne
