Saying Goodbye to AR2882 | Oct 15th 2021
- Has thanked: 1171 times
- Been thanked: 1360 times
Heya,
I got a break this evening in late afternoon daylight time, 4pm Eastern approximately, to watch the parting activity of AR2882 as it goes around the limb. There's an interesting prominence region and some little disturbances here and there, but otherwise the disc is very empty again. Though it looks like something powerful may be coming our way soon. I finally got around finishing a project involving being able to use my 214mm multi-band DERF (Aries) on other scopes beyond my 200mm options, so had an excellent ERF holding cell 3D printed to fit smaller 150mm and 120mm options with a mask system to control the options and I got it done today so was able to get a first light with it and make sure everything functions correctly as I move towards my next mod step (involving a Lunt etalon).
B&W:
Colored:
Equipment:
150mm F8 Achromatic Doublet (C6R) with 1.25x GPC (F10)
Aries 214mm multi-band DERF in 3D printed 150mm ERF holding cell (Primary D-ERF)
Baader Red CCD-IR Block filter (2nd D-ERF)
PST Etalon + 10mm BF
IMX290 sensor (2.9um)
B&W:
Colored:
Equipment:
- Been thanked: 16694 times
Re: Saying Goodbye to AR2882 | Oct 15th 2021
Nice work Marty. The disc is starting to calm down now a bit with AR12882 leaving the scene. Today had some decent prominences which are well sgown in your images.
Thanks for posting.
Thanks for posting.
Very good images Marty. Well done. These are the best I’ve seen coming out of Florida in quite some time.
Phil
Phil
- Been thanked: 4340 times
Beautiful images Marty
Great to see the modded ERF mounts too.
- Has thanked: 8418 times
- Been thanked: 8163 times
Great images, Marty. I’m loving the ERF cell That’s a beast.
- pedro
- Has thanked: 14 times
- Been thanked: 6577 times
Fantastic work Marty
Pedro Re'
- Has thanked: 6181 times
- Been thanked: 7142 times
Stunning set of images, Marty!
Thanks for sharing,
Arne
Thanks for sharing,
Arne
- Rusted
- Has thanked: 8016 times
- Been thanked: 1938 times
A superb set!
Your efforts were well rewarded.
- Been thanked: 4786 times
Mighty Marty! Great imaging job! I like the cell!
Thanks for sharing.
Still no seeing for your C8 ?
Valery.
Thanks for sharing.
Valery.
- Has thanked: 9145 times
- Been thanked: 6025 times
Congratulations on the SPOD, Marty. Very nice images: great texture in the chromosphere.
Thanks all,
So to make it more useful day to day, I had this filter holding cell printed to hold the 214mm D-ERF in a cell that will mount on smaller aperture scopes so that I can use it with smaller refractors or my C8 alike, and modular. Love it. Works really well. No heat coming out the back of the refractor with the primary D-ERF up front and a selective secondary D-ERF to finish the blocking.
I will see about being able to use this big D-ERF in front of my Calcium scope too (a re-spaced 120mm objective) with a down step coupling that inserts into the back of the ERF cell seen above.
Really fantastic to be able to 3D print these things, inexpensively, and let me use the 214mm D-ERF on any of my instruments. Just great flexibility!
TL;DR: I just like the wider FOV of the 150mm F8 refractor and the seeing limits are easier on the image scales with it in HA and Continuum
I had some good summer seeing that was 0.8 arc-seconds or so, and could benefit the 200mm of the C8, but I actually dislike the FOV of the C8 for HA purposes, HA structures are so large it requires mosaics often to see their entire structure and so I actually prefer the FOV of a 120mm~150mm for HA purposes, still with some resolution for interest but simplicity of not needing to do a several panel mosaic to show an entire active region, or large swath of prominence at the limb, etc.
- Has thanked: 20440 times
- Been thanked: 10245 times
Always nice to see your images MArty!
