October 11 2021 AR12882 Ha C11
- Has thanked: 1277 times
- Been thanked: 1070 times
Hi all,
That was the last morning on Monday of a sunny dacade I decided to take my chances with hi-res. Within an hour session there were some happy moments of the seeing corresponding with C11 aperture, despite the average one as bad as 2-2.5". One of the captures is marked on SSM chart.
Setup: Aries ERF, C11, UV/IR, Quark chromo, focal reducer, 174mm.
Regards
Leo
Regards
Leo
- 2882
- Sun_20211011 093754_AIdPsO.jpg (1007.96 KiB) Viewed 478 times
- 2882 color
- Sun_20211011 091225_AIdPsO2 c.jpg (818.46 KiB) Viewed 478 times
- SSM
- Sun 20211011 SSM.jpg (371.08 KiB) Viewed 478 times
- Been thanked: 4419 times
Re: October 11 2021 AR12882 Ha C11
Gorgeous image Leo
You grabbed it in the best conditions you had and it paid off!
Excellent work! So sharp and noise free!
This is a clear evidence that a very good seeing can be met almost everywhere on the globe.
Thanks for sharing.
Thanks for sharing.
- Has thanked: 17831 times
- Been thanked: 16971 times
Very nice work Leo. Both images are truly professional grade!
- Has thanked: 9306 times
- Been thanked: 6141 times
- Has thanked: 17970 times
- Been thanked: 8904 times
Wow!! you really have mastered this I don't think I will be able to use my C11 until spring now
Many thanks to all for kind comments!
Alexandra, that's what I thought at first, but fortunately not. It's rewarding experience with a seeing for me also, indeed.
Wanna share one more, wider picture of the AR with a bit different processing, made of some overlapping images.
Capture and processing: ASI174mm FC, 7.7ms, Gain 128 (32%), 128fps. Stacking 400/5000-8000 in AS3! gives quite a low noise, AstraImage, Ps CC (noise reduction plugin).
thanks for looking
Leo
thanks for looking
Leo
- AR2882 Oct. 11
- Sun 20211011 093520 AId2Ps.jpg (1.19 MiB) Viewed 414 times
- VasilevIvan
- Has thanked: 399 times
- Been thanked: 266 times
Superb images, Leonid! Bravo!
Best regards, Ivan.
VANTIM. Two Brothers observatory.
Observatory Dome 2.85m
SolarMax II 60mm DS, SW MAK 150, SW 80 ED, TS-Optics 6'' f5,9, LightBridge 12'' // AZ-EQ6 Pro, HEQ-5 mount
DayStar Quark Chromosphere, Lunt CaK B1800, D-ERF Baader 6'' // ZWO ASI 174mm, ASI 183mm, ASI178mm, ASI462mc, Player-One Apollo-M MAX.
- Has thanked: 6276 times
- Been thanked: 7302 times
- Rob63
- Has thanked: 599 times
- Been thanked: 619 times
Some really spectacular details in these, well done Leo.
Rob.
Rob.
Quark Chromosphere, Lunt LS60MT DS, Lunt Ca-K B1200 module, Baader herschel wedge
Sky-Watcher ED120 & ED80, StellaLyra 8" CC
Sky-Watcher EQ6R-Pro, ZWO AM5
ZWO ASI120MM, ASI174MM, ASI290MM, ASI1600MM
- Ivan
- Has thanked: 3479 times
- Been thanked: 2260 times
- Has thanked: 20778 times
- Been thanked: 10455 times
Very good indeed Leo!
