For a change, the sky today actually was clear from mid morning well into the late afternoon. The seeing was tolerable at the start but became worse later in the day. I revived my Explore Scientific AR152 for some work and coupled it with a full aperture ERF + 35nm H alpha filter + 3X or 4X telecentric feeding into a Quark Combo and ASI290. Unlike my fairly compact LS152 even when double stacked, the lower end attachments on this scope left me with only about 15 cm from the ground. In all, this set up produced some good results.
The AVX mount was misbehaving in that when I made continuous small corrections in declination, it sometimes seemed to save up these corrections and apply them all at once after about 800 frames. I opened up the dec housing and adjusted the play between the driving motor gear and the driven dec gear and tested the movement. It seemed fine but a real world test will tell me if the problem was actually a backlash problem. I had already tried resetting the paddle and upgraded the firmware with no improvement.
Anyway, here are the results from this day's session.
Activity on Oct 24
- Been thanked: 1735 times
- Been thanked: 8793 times
Re: Activity on Oct 24
These are as delicate as lace, absolutely stunning proms and a magnificent AR too
- Been thanked: 4904 times
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
- Has thanked: 17581 times
- Been thanked: 16697 times
Very nice prom resolution!
JP
JP
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Very good images!
Marios S.Ioannou
Sketcher/Visual Observer
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
- Been thanked: 4340 times
Beautiful images Lou
Nice to see you got some time under the clear skies on Sunday too!
- Has thanked: 2412 times
- Been thanked: 4787 times
