AR2887 in high resolution
GreatAttractor
Has thanked: 747 times
Been thanked: 757 times
Post by GreatAttractor »
My results from Sunday (all stacked in AS!3 and processed with ImPPG).
90 mm refractor, Chameleon 3 (ICX445), poor seeing. Small surge, and something boiling on the limb (30-second intervals, 0:30 h total):
Off-band; I like how everything seems more lively, will definitely try again (30-second intervals, 0:24 h total):
GSO RC8; better results than before, but I don't know yet which of the following helped the most:
  • better seeing, for longer periods
  • more frames to stack thanks to a faster camera
  • replacing (as advised by Apollo) the Lunt's mini-ERF (colored glass) by Baader 2" Hα 35 nm filter; maybe I had been having thermal issues after all
"Nothing happening" animation of the AR (20-second intervals, 0:55 h total):
Best frame:
Another video, slightly more aggresive processing:
My software:
My images
Has thanked: 17974 times
Been thanked: 8906 times
Re: AR2887 in high resolution
Fascinating work Filip :bow :hamster: The images are superb and the animations are encaptivating :movie The off band one got me thinking, I was wondering why the material was flowing in and not out, then it dawned on me. As it is blue wing it has to be coming towards me and these arch filaments are facing the observer from that angle as it is near the edge of the disc, so you would be seeing the flow towards me. In fact, all the flow is towards me, it goes down at the top and at the bottom the flow is coming out at me. That guarantees blue wing :)
MAURITS
Has thanked: 2464 times
Been thanked: 4880 times
Post by MAURITS »
Beautiful Filip.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 9319 times
Been thanked: 6157 times
Post by ffellah »
Beautiful animations and high resolution work.
Has thanked: 17853 times
Been thanked: 16996 times
Post by DeepSolar64 »
Very nice animations and images, Filip! 👍🏻
Has thanked: 20819 times
Been thanked: 10489 times
Good results Philip! The seeing isn't even coming close to supporting that 8", stick with the smaller aperture until seeing allows.
arnedanielsen
Has thanked: 6305 times
Been thanked: 7324 times
Post by arnedanielsen »
Beautiful stills and animations, Philip!
Arne
Arne
