I missed the M Class by 30mins, by the time the scope was aligned and pointing, it had died down.
Multi panel mosaic to create a fun disc!
Oct 26 2021 - I missed the big M class
- Has thanked: 1075 times
- Been thanked: 1986 times
- Been thanked: 4900 times
Re: Oct 26 2021 - I missed the big M class
You haven't missed too much judging by all the proms and surface detail you have so well captured.
Thanks vm
Thanks vm
- Been thanked: 4427 times
Great FD image, and your mosaics are very even and smooth. Nice work
- Has thanked: 17849 times
- Been thanked: 16992 times
Nice work, Simon! I was set up and at the scope when the M class went off. It blew out quite a bit of ejecta and died down quite rapidly. I was hoping for some big post flare loops but saw only a low dome shaped one.
I am just now posting because I spent all available time before work at the scope.
Better late than never I guess.
- MAURITS
- Has thanked: 2464 times
- Been thanked: 4880 times
- Been thanked: 8906 times
- Been thanked: 4980 times
Simon:
Superb full disc mosaic, clean crisp and even.
What setup did you use?
Best regards.
Best regards.
I went with the 100mm f5.5 and a quark. I normally use the 150 but seeing was jittery.
