Oct 28th Flare Session - 1st Images
- Been thanked: 4340 times
Good day everyone...
I was not aware of the flare yesterday when I arrived home for lunch, and with a lot of cirrus cloud of variable density blowing through I only planned to grab a full disk set o of images. Once I looked at the sun through the LS80T solar scope I surprised to see a lot of flare activity around AR2887...I though the new AR on the eastern limb was to be the watch to watch for
I did capture the full disk images, which are posted below: With 6 AR's and one flaring as well as a nice collection of proms and filaments, I decided to try these with the Orion 130ED modded double stack scope. The brightness varied considerably as he clouds drifted past, but I think most of the captures came out ok. I have to go through them all yet, and have only processed two of AR2887 taken with short and long exposures to show the activity. Both were taken at approximately 16:48UT: I will post the balance of the images later today or on the weekend when I have some free time.
- Rob63
- Has thanked: 573 times
- Been thanked: 591 times
Re: Oct 28th Flare Session - 1st Images
Fantastic captures, thanks for posting and looking forward to seeing more.
Rob.
Rob.
Quark Chromosphere, Lunt LS60MT DS, Lunt Ca-K B1200 module, Baader herschel wedge
Sky-Watcher ED120 & ED80, StellaLyra 8" CC
Sky-Watcher EQ6R-Pro, ZWO AM5
ZWO ASI120MM, ASI174MM, ASI290MM, ASI1600MM
- Been thanked: 4787 times
- Has thanked: 6181 times
- Been thanked: 7142 times
Good timing... beautiful images of the activity.
Arne
Arne
- Been thanked: 8791 times
Wow!!! well done Brian, what timing I love the image with the lightning streak through it
Are these 15:48 or 16:48 UTC Brian? the X class was at 15:35 and yet these images look like they are the flare and not post flare an hour and a half later.
- Rusted
- Has thanked: 8016 times
- Been thanked: 1938 times
Well done Brian!
Some high quality images. With far more extensive flaring than my earlier capture.
The sun would have been gone here, for a couple of hours, judging by your timing.
My last capture was at 14.12 [UTC] With no visible flaring at that time.
12.50 [UTC] was the last sign of AR2887 obvious flaring amongst my captures.
Some minor flaring, well to the south, at 14.08 [UTC]
- Been thanked: 4904 times
Brian:
Superb images and congratulations for the SPOD.
Best regards.
Best regards.
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
- Ivan
Thanks everyone.
I posted (or thought I posted ) a reply to the timing question form Alexandra, but I don't see it...so I'll try again.
The full disk was imaged at 12:16 EDT and the close-up of AR2887 was captured at 12:48 EDT, which should convert to 14:16 and 14:48 UT. Based on these times was imaging a half hour past the big flare for the full disks and 70 mins later on the close-up.
I should have a few more close-ups in the images I have to go through yet. I'll post with the remainder of the images from the session.
- Been thanked: 16694 times
I got the alert on my SpaceWeatherLive app at 15:30 UT. And of all days to be cloudy!!
Nice work Brian, The flare is large and bright in your images. I bet it was really easy visually too!
Hi James...
Yes, at the time I was out the flare regions looked like a pair of thin rivers of brilliant white light, running roughly parallel to each other. If I had more time I would have spent more time visually, but I was afraid the clouds would put an end to the ability to get useful images so I concentrated on imaging.
- Has thanked: 9145 times
- Been thanked: 6025 times
Excellent captures, Brian, your timing was perfect ! Congratulations on the beautiful SPOD.
- Has thanked: 1305 times
- Been thanked: 63 times
Lovely images of the X1 flare despite the conditions. congrats on the SPOD.
John
John
Almost like "rivers of lava" but considerably more dangerous in reality.
Very well captured Brian and I only missed a visual looksy an hour or so earlier from a friends house with his Lunt LS35T-Ha scope..
Maybe another chance, as have seen similar previously - some years back.
Franco, John, and Terry...
Thanks for your comments...always appreciated
Timing was very fortunate as I had almost decided against going out because of the cloud, and had I been able to leave work a bit earlier I might have caught the main event. Still, vary happy to get what I did, and the SPOD too
- Has thanked: 8418 times
- Been thanked: 8163 times
Cracking images, Brian. Absolutely well deserved SPoD....congratulations.
I've been away for a few days attending a wedding and have been almost completely 'unplugged' so I'm just catching up on things. A lot of solar activity seems to have happened in the meantime with an X-class flare and incoming CME. I'll watch my magnetometer in anticipation.
Thanks for your comments Stuart
I know that if any effect takes place form the CME impact you will be able to catch it day or night with the magnetometer!
- Ibbo
- Has thanked: 2438 times
- Been thanked: 1650 times
Thanks Steve
