10 30 Ha, Cak, Continuum images
- Has thanked: 1640 times
- Been thanked: 878 times
Here are some images taken yesterday.
WL 150/1200 + 2x barlow +290
Ha: 150/1200 masked to 120 + baader TZ3 + 174 chip
CaK 150/1200 masked to 80 + 290
2021-10-30_AR2889wl by Diamond, Alan, on Flickr
2021-10-30_AR2891wl by Diamond, Alan, on Flickr
2021-10-30_AR2892wl by Diamond, Alan, on Flickr
2021-10-30_AR2887WL by Diamond, Alan, on Flickr
2021-10-30_T_11-40-42-0565_L_lapl4_ap653 by Diamond, Alan, on Flickr
2021-10-30_AR2891 by Diamond, Alan, on Flickr
2021-10-30_AR2887 by Diamond, Alan, on Flickr
2021-10-30_T_11-36-36-0860_L_lapl4_ap6336imppg by Diamond, Alan, on Flickr
2021-10-30_AR 2891 Ca by Diamond, Alan, on Flickr
2021-10-30_AR2887ca by Diamond, Alan, on Flickr
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
Re: 10 30 Ha, Cak, Continuum images
Fantastic set of images!
I particularly like the CaKs.
Arne
Arne
- Been thanked: 8793 times
Wow!!! incredible images, my favourite is the crackle and pop CaK
- VasilevIvan
- Has thanked: 397 times
- Been thanked: 264 times
Alan, all images are fantastic! Lucky with the atmosphere
Best regards, Ivan.
VANTIM. Two Brothers observatory.
Observatory Dome 2.85m
SolarMax II 60mm DS, SW MAK 150, SW 80 ED, TS-Optics 6'' f5,9, LightBridge 12'' // AZ-EQ6 Pro, HEQ-5 mount
DayStar Quark Chromosphere, Lunt CaK B1800, D-ERF Baader 6'' // ZWO ASI 174mm, ASI 183mm, ASI178mm, ASI462mc, Player-One Apollo-M MAX.
- Has thanked: 2412 times
- Been thanked: 4787 times
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Fantastic images as usual Alan!
I very much liked the definition of the Ha (apart the WL for which I always have a preference...).
Is masking efficient for you? Have you run conclusive tests?
Congratulations for the SPOD!
Alexandros
Alexandros
Alexandros
Greece
Greece
- Been thanked: 4340 times
Excellent images Alan
- Has thanked: 20442 times
- Been thanked: 10248 times
These are really good Alan!
Thanks. I have to mask my 150 F8 to achieve at least F30 for the Daystar and TZ-3. Of course this should be around F50. I am still testing the quantum to see if .3A is possible with this unit. This session I had best results around 656.18 or 2.0. I still need to test as I have had conflicting results between sessions. I suspect that is user error on my part. This weekend, the weather should allow testing at F30 and F50ish.
- rigel123
- Has thanked: 8316 times
- Been thanked: 8544 times
Excellent Alan!
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
