Thanks to the SpaceWeatherLive app on my phone I get alerts when the sun bursts forth flares. I first got an alert around 22:00 UT and checked SWL and found a C class flare in progress. Checking my SDO viewer app I find that the SDO images confirm this. It's located in AR12887 in the SW quadrant of the solar disc. Another image just under an hour later reveals a post-flare loop! A while later around 02:50 UT I get another alert. This one is an M Class flare in AR12891! GONG Learmonth shows this one splendidly in Ha.
I observed the Sun from work! Virtually using the GOES, SDO and GONG!!
Here's the data and images.
Monday evening flares!
- Has thanked: 17849 times
- Been thanked: 16992 times
Re: Monday evening flares!
https://www.spaceweather.com/images2021 ... l_anim.gif shows well the AR2891 flare - earlier this morning/2-11-2021.
Thanks for the updates James..
Things have really been " flaring " up lately!!
Terry, Even though UT time has it on Tuesday morning it happened before midnight in my local time zone so I listed in my records as on Monday late. Same flare though. Thanks for the additional GIF SDO animation.
Thanks for that James and i guess another example of everybody just using one time zone for absolutely everything.
Here it now so much easier (for six-months) and both my new mini-obsy clocks are now showing just the one time as "Z"...
- Been thanked: 4427 times
Thanks for the heads up James!
At that point on the limb I would expect at best a glancing blow, but will see what the effects are.
EGRAY_OBSERVATORY wrote: ↑Tue Nov 02, 2021 9:59 pm Thanks for that James and i guess another example of everybody just using one time zone for absolutely everything.
So true Terry. In ways I like the idea of the UTC being used instead of the time zone system, but I would have trouble with the time not lining up with the day as one sees it in their part of the world. Everything has it's advantages and disadvantages I guess.
JP
