AR2893, AR2891, AR2887 | WL, CaK, HA | Nov 2nd 2021
- Has thanked: 1171 times
- Been thanked: 1360 times
Heya,
I had a brief moment of good seeing (approx 1 arc-second average) and clear sky this late morning, around 11am Eastern time. Not much was popping off, but AR2891 has been so active so I was curious to see if it was going to toss a flare by chance. AR2893 hasn't been doing much but is a larger spot with a lovely light bridge. AR2887 is rounding the limb and is really interesting in Calcium with all the faculae around the area.
B&W:
Colored:
Equipment:
150mm F8 Refractor + Aries 214mm DERF (Primary DERF) in 150mm masked 3D Printed Cell + Baader Red CCD-IR Block (2nd DERF)
+ Lunt LS60MT Etalon + 12mm BF + IMX290 (HA)
150mm F8 Refractor + Baader Ceramic Cool 2" Wedge + ND3.0 + Baader Continuum 540nm + 1.6x barlow + IMX290 (WL)
100mm F10 Refractor + Lunt CaK B1200 + 1.6x barlow + IMX290 (CaK)
B&W:
Colored:
Equipment:
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Re: AR2893, AR2891, AR2887 | WL, CaK, HA | Nov 2nd 2021
Very nice Marty. Really like the WL images.
Dan
South central Indiana
USA
USA
Fab presentation of so many excellent images Marty.
Thanks vm for sharing
- Been thanked: 4340 times
Superb images and presentation of them today Marty...nicely done
- Has thanked: 17581 times
- Been thanked: 16697 times
Very nice work, Marty!
Is your 100mm refractor a 102? Celestron?
JP
JP
- Been thanked: 4787 times
- Has thanked: 9145 times
- Been thanked: 6026 times
A beautiful set, Marty, very well done.
Hi,DeepSolar64 wrote: ↑Wed Nov 03, 2021 4:49 am Very nice work, Marty!
JP
It's a Celestron Omni XLT 120mm F8.3 achroamtic doublet with a linear bearing GSO focuser; very inexpensive. I respaced the lenses with a larger air gap based on Mike Jone's best-guess calculations for best performance in near UV. I did this originally on my CR150HD (C6R), but reverted it for HA use and instead did this to my 120mm F8.3 instead. Then I typically mask it to 100mm F10 when seeing is only around 1 arc-second. When seeing is sub-arc-second, I open it up to the full 120mm and take it to F13 to F16 depending on seeing (but requires 0.6~0.8 arc-seconds, which I get sometimes, but not weekly).
- Has thanked: 1640 times
- Been thanked: 878 times
I like the lunt 60mod. It appears that you didn't use the 3d printed adapter?
- Been thanked: 4904 times
Marty:
A very good session, beautiful images all of them.
Thanks for sharing them.
I did use the 3D printed adapter at first, but then I re-measured everything and found I needed to take off more OTA. It needed -240mm to -265mm range back focus. So I had to take more off the OTA. At that point, I also looked into a metal threaded adapter as I found out the threaded end of the Lunt 60's chamber where the internal ERF threads on, is M50x1 threads (same as a PST). So I was able to get off the shelf M50x1 to M48x0.75 (2" standard) adapters and convert the Lunt etalon to a simple 2" metal nosed modular filter without any modding or destruction at all. And the M48x0.75 threading allows for standard 2" filters, so I could put a 2nd DERF on it too. So now I just insert into my focuser and it's ready to go, at full 150mm aperture. I'm using my big 214mm Aries DERF in a big 3D printed cell that masks it to 150mm clear aperture, F8 native, and that's the big white assembly seen in the image above. I'll post more about it soon in its own thread.torsinadoc wrote: ↑Wed Nov 03, 2021 1:02 pm I like the lunt 60mod. It appears that you didn't use the 3d printed adapter?
- Has thanked: 8418 times
- Been thanked: 8165 times
Fabulous, Marty. An excellent set of images.
- Been thanked: 8793 times
These are absolutely magnificent Marty, I can see the Bright Ring around 2893 in both your CaK and WL images so this one is definitely one to add to the list.
