Chilly fingers and stiff wires on Nov 6
- Been thanked: 1735 times
The temperature wasn't really that bad (10˚C) but the events I saw gave me optimism about this session and made me forget the slight discomfort. Seeing was variable, sometimes producing an image with blooming details popping in and out of focus which sometimes changed to jittery images. The best seeing happened early in the session and worsened as clouds moved in. Seeing between clouds was very bad but imaging through thinner sections of clouds seemed to settle the seeing down. I used an AR152 with either a 3X telecentric + Quark Combo or Standard Quark for the images below.
Lou
Lou
Re: Chilly fingers and stiff wires on Nov 6
Beautiful captures Lou - showing such fine detail and colouring
Thanks vm
Thanks vm
- Been thanked: 4340 times
Hi Lou...
Those are fabulous hi-res images
Glad that you got some time under the sun.
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Hi Lou, when I saw these pictures, I thought oooooo, wow!
Ivan
Ivan
Thanks, Terry, Brian, and Ivan for the comments.
Often, I can't tell from the raw image whether sharpening will work well or not. I also said "O, wow"
Then, I also realized that my time for comfortable imaging is also almost over this year and I regret that the sun wasn't more interesting
this past summer. At least I learned that with some processing, even in less ideal conditions, you can produce good images.
Sunday (today) looks like a better day than Nov 6 and I'll try to image some of the same features.
Lou
Lou
- Has thanked: 8415 times
- Been thanked: 8161 times
Nice images, Lou. That prom is superb.
- Been thanked: 16689 times
Nice work Lou! That prom is really nice and there's a lot of depth and detail in and around that filament.
- Ibbo
- Has thanked: 2438 times
- Been thanked: 1650 times
- Has thanked: 1640 times
- Been thanked: 878 times
- Has thanked: 17648 times
- Been thanked: 8787 times
Terrific images I really like the filament, it reminds me a of Salmon leaping through the rough waters
- Has thanked: 20424 times
- Been thanked: 10242 times
Nice shots here Lou!
- Has thanked: 1304 times
- Been thanked: 63 times
Thanks for sharing such beautiful images, a joy to view.
John
John
- Has thanked: 6181 times
- Been thanked: 7142 times
Good work, Lou!
I like both the disc and the prom image very much!
Arne
Arne
- Been thanked: 4786 times
- Rob63
- Has thanked: 573 times
- Been thanked: 591 times
Lovely set of images.
Rob.
Rob.
Quark Chromosphere, Lunt LS60MT DS, Lunt Ca-K B1200 module, Baader herschel wedge
Sky-Watcher ED120 & ED80, StellaLyra 8" CC
Sky-Watcher EQ6R-Pro, ZWO AM5
ZWO ASI120MM, ASI174MM, ASI290MM, ASI1600MM
- VasilevIvan
- Has thanked: 397 times
- Been thanked: 264 times
Fabulous images Lou, especially prominence! Bravo!
Best regards, Ivan.
VANTIM. Two Brothers observatory.
Observatory Dome 2.85m
SolarMax II 60mm DS, SW MAK 150, SW 80 ED, TS-Optics 6'' f5,9, LightBridge 12'' // AZ-EQ6 Pro, HEQ-5 mount
DayStar Quark Chromosphere, Lunt CaK B1800, D-ERF Baader 6'' // ZWO ASI 174mm, ASI 183mm, ASI178mm, ASI462mc, Player-One Apollo-M MAX.
- Has thanked: 54 times
- Been thanked: 73 times
Excellent capture of the big prominence and active regions.
80mm f6 Officina Stellare APO triplet, 152mm Officina Stellare f8 APO triplet, TV 85mm f7 ED APO, 8" SCT HD, 11" SCT.
Astro Physics 900 and 1100 mounts, Ioptron MINI Tower Pro ALT/AZ mount, ZWO AM5 mount,
Lunt 60mm Ha single stack, Coronado 60mm Ha single stack with BF 30
Day Star Quark Chromosphere
Player One Neptune mono with 178 chip, 256mm DDR, tilt plane for solar imaging
ASI 071 Pro cooled color for DS imaging
ATIK 490 EX OSC for DS imaging
SBIG STL 6303e mono with RGBL and Ha, SII, OIII filters for DS imaging
ASI AIR Plus
JPL/NASA Solar System Ambassador
Michigan Scout observatory manager
ASI AIR Plus
