Sun on 15th, Nov, 2021, ES127+Quark+Apollo-M MAX cam
- MoonPrince
- Has thanked: 7 times
- Been thanked: 228 times
oday's Sun. A clear day for solar imaging.Still use ES127CF F7.5 APO and Daystar Quark, and Player One Astronomy Apollo-M MAX (IMX432) for chromosphere imaging.
In fair seeing condition, 9um pixel size is much easier to get sharp details under F32 ratio.
All images use normal pattern to show up the surface.
Exposure 7-8ms, gain 150, 2000 frames, 30% stacked.
Normal pattern:
reverse pattern:
Prominence:
Normal pattern:
reverse pattern:
Prominence:
Telescope: ES127CF APO F7.5, LXY80APO F6
Mount: SW AZEQ6, iOption GEM45.
Camera: Player One Apollo-M MAX(IMX432), Apollo-M(IMX174), Apollo-M MINI(IMX429)
Accessories: Daystar Quark Chromosphere, Herschel prism, TV5X, TV2.5X
- pedro
- Has thanked: 14 times
- Been thanked: 6575 times
Re: Sun on 15th, Nov, 2021, ES127+Quark+Apollo-M MAX cam
Nice images with the Quark Chromosphere
Do you use flats to obtain your Quark images?
Pedro Re'
- Been thanked: 4900 times
- Has thanked: 8415 times
- Been thanked: 8161 times
Nice images.
- Has thanked: 20424 times
- Been thanked: 10243 times
That's a nice run of images! I would consider using a full size DERF longer term with a 5" scope and a Quark...
- MoonPrince
Yes, I took 2000frames flat and made a master flat for thoes chromosphere image. But for Prominence, no flat will be better.
- MoonPrince
ERF is better option, I just use a UV IR-cut filter in front of quark. I think it's not very good in summer, to much heat will on quark.marktownley wrote: ↑Tue Nov 16, 2021 6:15 am That's a nice run of images! I would consider using a full size DERF longer term with a 5" scope and a Quark...
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4786 times
- Has thanked: 9144 times
- Been thanked: 6025 times
Well done, a very nice set of images.
- MoonPrince
Thanks a lot, Maurits. Still got a lot need to learn in post-processing.
- MoonPrince
Thanks, Franco. I see someone use imppg for post-processing, and looks quite well. I will try that next time.
- Been thanked: 4904 times
Hi:
A super set of images.
Thanks for sharing.
Thanks for sharing.
- Been thanked: 91 times
Nice capture, MoonPrince, the new camera is very exciting.
Clear Sky & Regards
Stephen
Stephen
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
Beautiful set of images!
Arne
Arne
- Has thanked: 17666 times
- Been thanked: 8787 times
A superb set beautiful detail and lovely processing
- MAURITS
