Sun FD in H-Alpha 17th of November 2021
- arnedanielsen
- Has thanked: 6296 times
- Been thanked: 7311 times
Dear friends,
Short window with clear skies, but with poor seeing. Just managed to get my FD images in Ha and CaK.
Solar altitude 11 degrees.
FD image in H-Alpha using a Coronado 60mm/BF15 w/Beloptik ITF, stopped down to 50mm, Baader 35nm H-Alpha and ASI 178mm mounted on a SkyWatcher SolarQuest. Sun FD in H-Alpha 17th of November 2021
Sun FD in H-Alpha 17th of November 2021 - Colorized
FD image in CaK using a William Optics ZenithStar 61II, stopped down to 46mm, Lunt CaK 1200 module, Coronado 2x CeMax and ASI 183mm camera mounted on a SkyWatcher SolarQuest. Sun FD in CaK 17th of November 2021
Sun FD in CaK 17th of November 2021 - Colorized
Click on links to view full size images.
Thanks for looking and best regards,
Arne
Arne
- Been thanked: 4900 times
Re: Sun FD in H-Alpha 17th of November 2021
Well done Arne on your excellent FD's.
Thanks for sharing
Thanks for sharing
- Has thanked: 20783 times
- Been thanked: 10468 times
Lovely disks Arne!
- Has thanked: 8544 times
- Been thanked: 8282 times
Very nice, Arne.
- Been thanked: 8905 times
These are super Arne, I like the filament which is nearing the western limb, it looks very 3D and would make an excellent close up
- Has thanked: 9307 times
- Been thanked: 6144 times
Excellent captures and processing Arne, thank you
- arnedanielsen
- Ibbo
- Has thanked: 2443 times
- Been thanked: 1650 times
- Been thanked: 4423 times
These are a very nice set of FD images Arne...well done
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Hi Arne,
Amazing work, and lovely looking sun.
Thanks for sharing.
Magnus
Thanks for sharing.
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- MAURITS
- Has thanked: 2464 times
- Been thanked: 4880 times
- arnedanielsen
Thanks everyone for you kind comments.
Arne
Arne
- Has thanked: 17845 times
- Been thanked: 16979 times
Very nice work Arne. You have done very well with that low sun from Norway!
- arnedanielsen
You are welcome Arne. Your images look really good!
- Been thanked: 4971 times
Arne:
Beautiful FD´s in spite of bad seeing.
Best regards.
Best regards.
- arnedanielsen
