Session time is from 16:15 to 17:00 UTC. Clear skies with poor seeing. The temperature is 46F ( 7.7C )
Today I notice only two active regions on the disc. AR12896 is in the SE nearing the Central Longitudinal Meridian. I had to look closely to see it at all. It's just a mere ruffled disturbance in the chromosphere. I see no real plage at all and never could see the spot. If I would have not known exactly where to look I would have overlooked it completely. AR12897 in the NE is easier due to it's visible plage. I never could see it's spot either. Seeing maybe? The spots are fairly small.
I see four filaments on the Ha disc. Two in the SE with the northernmost one being the S shaped snake prom I saw yesterday. I also see an easy one near the CLM in the NE and another one in the NW quad.
I can see a bright easy but fairly small prom on the NW limb and a set of " bush " proms on the SW limb. I can also see a few proms on the eastern limb as well but they are faint in double-stack.
The mottles are visible but a bit soft in the poor seeing.
Both AR12896 and AR12897 show up only as small spots. Though the SDO images indicate they do have penumbrae I cannot see them due to the spots small size and poor seeing conditions. I see no other details on the disc. No faculae and the solar granulation is barely detectable at all.
Carpe Noctem!
Have a good weekend.
November 19 2021 Observations
- Been thanked: 16689 times
Re: November 19 2021 Observations
Thanks vm James for the latest.
I might as well go to sleep, as been up all night looking-up some info and wanted to complete a task early and hopefully catch some Sun, but no chance.
So the grass needs a final cut of the year and then kip..
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Great description, James, the sun seems to be taking a short break right now.
Ivan
Ivan
I raked leaves and cut grass last weekend. There’s so many more leaves fell since that I can’t tell I did anything. I have plans to get out there tomorrow to do them again.EGRAY_OBSERVATORY wrote: ↑Sat Nov 20, 2021 12:14 pm Thanks vm James for the latest.
- Has thanked: 20424 times
- Been thanked: 10242 times
45 minutes well spent James. Your temperatures are similar to ours at the moment. Thanks for the report.
Today is colder. I'll post today's brief session shortly.
- Has thanked: 17651 times
- Been thanked: 8787 times
Thanks for the great report James, I have my fingers crossed for tomorrow it will be clear. We have been raking leaves too, every Saturday for a few weeks now and I am sure for another few weeks ahead. The job is never done as more fall every minute.
Montana wrote: ↑Sat Nov 20, 2021 4:22 pm Thanks for the great report James, I have my fingers crossed for tomorrow it will be clear. We have been raking leaves too, every Saturday for a few weeks now and I am sure for another few weeks ahead. The job is never done as more fall every minute.
It’s all a part of autumn I guess. It and the low sun.
