November 21st Ha Session
- Been thanked: 4428 times
Good day everyone...
Sunday morning started off clear here with moderate seeing, so I went out to view/image before the forecast clouds made an appearance. The two AR's on the disk were not overly active, but the large number of filaments and proms certainly added to the Ha experience
The first image is a FD Ha composite that was taken through the DS LS80T/LS75FHa/B1800Ha and an ASI1600MM camera and 1.6x barlow: My DS modded OTA was used to image the AR's, filaments, and proms in greater resolution. This system is comprised of the Orion EON 130, fitted with a pair of Lunt DSII etalons and a B1800Ha blocker. The camera was an ASI290MM and 1.3x barlow. The first images are AR2897 and AR2896 shown in mono, inverted, and colorized palettes: The southern hemisphere contained all of the filaments, many of which showed a lot of structure: I finished the session off by capturing images of the prominences...the most detailed ones were on the SE limb and the balance were fairly small. My last capture was aimed at the NW limb as the clouds set in so this has very poor contrast This covers the images from my latest session. I was able to work on the new observatory through the afternoon, and I am making slow progress on it...though progress it is Cold and windy today with rain and snow squalls limiting more work, but I may take a few days of holiday time to work on it this week on clear days.
Thanks and take care,
- Been thanked: 10489 times
Re: November 21st Ha Session
Great set of images Brian! Glad things are progressing with the build.
Thanks for your comments and feedback Mark...much appreciated
Great session Brian, you caught some lovely images of the proms and filament
- Oh, I get it now!
- Has thanked: 14 times
- Been thanked: 72 times
All has been said Brian and thanks again for your excellent captures
- Has thanked: 9326 times
- Been thanked: 6158 times
Thanks everyone for all of your positive comments on the session...always appreciated
- Has thanked: 17853 times
- Been thanked: 16998 times
Brian,
This is a truly outstanding set of images. Images 5, 6 and 7 show the mottles looking a bit " roughed up ". Image 10 is absolutely beautiful!! And I love how you have partially eclipsed some of the images.
Two thumbs up!!
Two thumbs up!!
- Been thanked: 4980 times
James and Eric...
Thanks to each of you for your comments on the images
James, I blacked out the over exposed portion of the chromosphere but didn't take it to eh limb since there was still details present. I agree it looks like an eclipse
- Has thanked: 6305 times
- Been thanked: 7324 times
- Has thanked: 8559 times
- Been thanked: 8291 times
An excellent session, Brian, with great results. Beautifully captured filaments, proms and close views of the active regions.
Arne and Stuart...
I appreciate your comments and feedback on the images from this session
Thank you Jacinto !!!
