Sun in Ha and CaK 25th November 2021
Has thanked: 8418 times
Been thanked: 8165 times
Post by Carbon60 »
Hi all,
A few images in Ha and CaK from this morning. The forecast was for blue skies....well, that was partly true. The sky was blue for the most part, except for haze and thin clouds right where they were not wanted; right in front of the Sun.
Anyhow, I did manage a couple of FD mosaics and even a close view of AR12898 on my 150 mm mod.
First up are my CaK FDs:
Image20211125_CaK_FD_Mono by Stuart Green, on Flickr
Image20211125_CaK_FD_Colour by Stuart Green, on Flickr
...and then my Ha FDs:
Image20211125_Ha_FD_Mono by Stuart Green, on Flickr
Image20211125_Ha_FD_Colour by Stuart Green, on Flickr
Finally the closer view of the newest active region with degrading seeing:
Image20211125_Ha_AR12898 by Stuart Green, on Flickr
I did try to make a mosaic of the active region, but only two out of four panes turned out okay with the other two a bit blurred. Oh well...
Thanks for looking.
arnedanielsen
Has thanked: 6181 times
Been thanked: 7142 times
Re: Sun in Ha and CaK 25th November 2021
Post by arnedanielsen »
Good work, Stu! The images turned out well despite the haze and thin clouds!
Arne
Arne
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Thanks Stu for your excellent images.
AR2898 seems to be flaring - so now with up to ten-spots it could well prove very interesting...
Has thanked: 17672 times
Been thanked: 8793 times
These are masterpieces Stuart :bow :hamster:
I had a meeting at work and the Sun was so low and bright they were complaining and wanting to put the blinds down. I protested, but they couldn't get the blinds to work anyway :lol: so I was enjoying the Sun's rays instead.
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Hi Stu,
Very nice session!.
Albeit... "Finally the closer view of the newest active region with degrading seeing".
This is a common mistake. High res imaging should be done FIRST! Then all kinds of FDs, which can be good even in not so good seeing.
Has thanked: 9145 times
Been thanked: 6027 times
Post by ffellah »
Fabulous pics, Stu.
Has thanked: 17581 times
Been thanked: 16697 times
Post by DeepSolar64 »
Valery wrote: Thu Nov 25, 2021 7:28 pm Hi Stu,
Very nice session!.
Valery, I agree with you. Often at the beginning of a session the seeing is better as the air heats up as the day wears on. This of course applies to visual as well. Do high rez or view with higher magnification at the beginning of a session for the seeing usually degrades later on. I have learned this by experience.
Excellent work on all Stuart. The CaK image is my favorite, it shows the plages so well!!
Post by Carbon60 »
Montana wrote: Thu Nov 25, 2021 6:05 pm These are masterpieces Stuart :bow :hamster:
I like it…your colleagues would just have seen a bright light. You, on the other hand, have a deeper understanding, more insight and absolute appreciation of what the Sun actually is. No doubt flares, filaments and proms were coming to mind as you sat and absorbed the majesty of our star. :seesaw
Post by Carbon60 »
Very nice session!.
You are absolutely correct, of course, Valery, and usually hi-res does come first with FDs as a follow up. However, on this and a few other occasions I had no real expectations, or intention, to get out the big gun, but I couldn’t resist when I saw the bright active region and wanted a closer look. I figured I’d either get a good result or not. In the end it turned out reasonably okay. With a lower Sun, down my street, with houses and a main road close by hi-res is an even bigger challenge at this time of the year.
eroel
Been thanked: 4904 times
Post by eroel »
Stu:
Beautiful session, thanks for sharing.
BTW, I start my sessions with the Solarmax 90-DS and if I see that the seeing is regular to good, then I also connect the heater of the old Daystar T-Scanner that takes about 15 minutes to get to the correct temp on the 102mm Stellarvue working at f/28, then finally I use the 102mm f/9 Meade refractor with the CaK mod.
If I see that the seeing during the Solarmax 90-DS is not regular to good, then I do not even try with the rest of the scopes.
Best regards.
Ivan
Has thanked: 3465 times
Been thanked: 2250 times
Post by Ivan »
Brilliant work, Stu. FD in Ha broke my heart.
Ivan
Has thanked: 64 times
Been thanked: 4340 times
Post by MapleRidge »
Great images Stuart...great to see your captures from the session :bow
Has thanked: 20442 times
Been thanked: 10248 times
Very good indeed Stu, glad you got some sunshine!
Post by Carbon60 »
Many thanks, Eric, Ivan, Brian and Mark.
