AR2898 SEEMS TO BE FLARING TODAY 25-11-2021
The heading says it all and with at least 10 spots and more, an interesting layout developing very nicely over the last 24-hours.
More action expected soon approaching the Eastern Limb...
- 25-11-2021 1553z SDO-AR2898 latest_4096_HMII.jpg (84.13 KiB) Viewed 415 times
- Been thanked: 8791 times
Re: AR2898 SEEMS TO BE FLARING TODAY 25-11-2021
That does look a complicated shape, the more complicated the more the lively
Certainly is a fairly unusual shape for the AR2898 complex, but then we have seen the long/large filament in the south as also unusual.
- Been thanked: 16694 times
I didn't get lucky enough to get a flare in today's 2 hour session. At 540nm the AR12898 complex looks pretty much as the SDO image shows it.
Thanks Terry.
Thanks Terry.
Thanks James and the picture I saw earlier elsewhere seems to show minor-flaring from AR2898.
Depending on the polarity of all these sets of spots, a larger flare is quite likely.
My only two slightly successful captures today, show much as the SDO image shows, but of course the SDO is far superior.
- 25-11-2021 12_04z Sodium AR2898.jpg (39.07 KiB) Viewed 391 times
- 25-11-2021 1231z WL-HW AR2898.jpg (23.95 KiB) Viewed 391 times
Looks good, Terry!
- Been thanked: 10247 times
Looks a nice active region Terry, have you tried 2x2 binning with the camera? It will help with the winter seeing.
I did try that Mark and can't recall the results, so will look back on the mini-obsy pc to see what it captured.
Thanks for mentioning that.
