Sol from the 25th of November 2021.
- Been thanked: 4904 times
Hi:
Got some images, seeing jumpy and sky hazy and cloudy, so just had a quick chance to image.
Thanks for looking.
Wish you all a nice and sunny weekend.
Thanks for looking.
Re: Sol from the 25th of November 2021.
Considering either you or the seeing was jumping around Eric, you have still captured an excellent set of images..
Thanks for sharing and have a good weekend - not jumping around either !!
Regards
terry
Regards
terry
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Terry and Ivan:
Thanks for the feedback, as for the seeing, well here is the SSM graph of the 25th, normally when sunny and mostly clear, the input shows 0.8, so as you can see it was lower and the seeing with interruptions due to clouds passing by and jumpy.
Have a nice weekend too.
- Has thanked: 8418 times
- Been thanked: 8162 times
A great set of images, Eric.
- Has thanked: 17572 times
- Been thanked: 16694 times
Very nice detail Eric. I notice especially the last one of the southern prominence. :-)
Thanks for that description and the image Eric.
Here in much of the U.K. and particularly my region in the S.E., any scopes outside or not tied down will likely be jumping around, due to the high/very-high winds forecasted. Then even covered in snow is a possibility..
Stu, James and Terry:
Thanks for commenting.
As for jumping seeing, I mean that the seeing is changing continuosly with no steady repeating periods.
My home observatory is on the roof and I have the 4 scopes mounted on a sturdy permanent steel pier, but cars and trucks passing in front of my house, make my setup vibrate a bit, so I have to take that in account also when imaging.
Best wishes for you all.
Eric, with the observatory not on the ground floor on a concrete pad you must have one sturdy house to mount that steel pier in!!
- Been thanked: 4340 times
Superb images Eric...well done
- Has thanked: 20435 times
- Been thanked: 10245 times
Great images Eric!
- Has thanked: 17667 times
- Been thanked: 8789 times
Beautiful images, especially the last one of the prominence
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
Very nice despite the not so favorable conditions.
Thanks for sharing,
Arne
Thanks for sharing,
Arne
