28 Nov FD. Recalibrating my equipments
- minhlead
- Has thanked: 738 times
- Been thanked: 1104 times
I am recalibrating my equipment and refining my work flow for full disk with my Quark. What do you think? Solved most of the sweet spot problem due to uniformity but still got some bad spots on my pic.
Minh.
Loves from Viet Nam <3
My gear:
Mount: JTW Tridents GTR
Camera:
PlayerOne Apollo M-Max
My gear:
Camera:
- minhlead
Re: 28 Nov FD. Recalibrating my equipments
I also took a small animation. Did not get a lot of movement but it's a good start I guess
Minh.
My gear:
Camera:
My gear:
Camera:
- Has thanked: 20424 times
- Been thanked: 10243 times
Both of those are excellent Minh, you seem to have the full disk sorted!
- Has thanked: 9144 times
- Been thanked: 6025 times
- rigel123
- Has thanked: 8310 times
- Been thanked: 8537 times
Nice one Minh! Are you using IMPPG for your batch processing? I noticed the “dancing bullseye” that I sometimes get with IMPPG in animations as well and sometimes changing the mode from CPU + Bitmaps to GPL/Open GL (I think those are the two modes) will avoid that little artifact. If not I simply clone it out in any frame it displays in. It usually doesn’t show up in every frame.
- minhlead
Thanks, Mark. I still want to try and find a cropped FOV with better uniformity. Maybe will rotate the camera a bit tomorrow and see if it works. I doubt it will though since the disk already quite big and the bad spot is right in the middle.marktownley wrote: ↑Sun Nov 28, 2021 11:54 am Both of those are excellent Minh, you seem to have the full disk sorted!
Thanks Franco.
I am using IMPPG and PixInsight for batch processing. IMPPG does a very good job with curving and deconvolution and aligning (best in class I must say, especially it's free) but the result from IMPPG can magnify the un-uniformity giving the disk a "mottled" look. PixInsight step in to save the day with it HDR compression . The dancing bullseye IMHO is due to hot pixel that get ringing due to the deconvolution process rather than an artifact of the processing engine (deconvolution has a tendency to add a dark ring around high contrast edges). On my previous camera (a cooled 294C) the problem is more pronounced when I forgot to turn on the cooler. Maybe I'll test this theory by taking dark frame to calibrate my light and flats, see if it works.rigel123 wrote: ↑Sun Nov 28, 2021 12:50 pm Nice one Minh! Are you using IMPPG for your batch processing? I noticed the “dancing bullseye” that I sometimes get with IMPPG in animations as well and sometimes changing the mode from CPU + Bitmaps to GPL/Open GL (I think those are the two modes) will avoid that little artifact. If not I simply clone it out in any frame it displays in. It usually doesn’t show up in every frame.
Minh.
My gear:
Camera:
My gear:
Camera:
- Been thanked: 16691 times
They look really good to me!
- minhlead
Thanks, James. Long time no see!
Minh.
My gear:
Camera:
My gear:
Camera:
That big filament will be on the limb in just hours as a prom!
Super capture, animation and processing Minh.
Thanks for sharing
Thanks for sharing
- Been thanked: 4340 times
These images look very good Minh...pretty uniform across the disk !!!
- Been thanked: 4904 times
Minh:
Beautiful FD image and animation.
Best wishes.
Best wishes.
- rigel123
[/quote]
[/quote]
I’ll be interested in your results on that bullseye, I think you might be right about the hot pixel, I’ll keep an eye on that in further captures. I never see it when working with single captures, it only pops up when batch processing in IMPPG, which I agree, is a wonderful program!
[/quote]
- minhlead
I tested it on a single frame and sure enough, after the hot pixel is removed with the help of cosmetic correction in PixInsight, the bulleyes is gone.rigel123 wrote: ↑Mon Nov 29, 2021 2:40 am I’ll be interested in your results on that bullseye, I think you might be right about the hot pixel, I’ll keep an eye on that in further captures. I never see it when working with single captures, it only pops up when batch processing in IMPPG, which I agree, is a wonderful program!
Curiously enough, the most of the hot pixels is not visible on the lightframes except for a few (single frames has a lot of them). I guess most of the stationary hot pixel will get averaged out with aligning and stacking. Anyway, I'll try to capture and use dark frame with my light sub to see if it works.
Minh.
My gear:
Camera:
My gear:
Camera:
- Has thanked: 17667 times
- Been thanked: 8787 times
The animation is incredible :hamster the dance of the filaments :
Is north to the right?
- minhlead
Yeah. North is to the right. I am not paying close attention to orientation. I think I'll get some time to educate myself on this.
Minh.
My gear:
Camera:
My gear:
Camera:
