Amazing animation made at Big Bear T 1.6 m solar telescope
- Been thanked: 2713 times
Here is an amazing animation made with adaptative optics at Big Bear anda TiO filter :
https://est-east.eu/index.php?movie-con ... pot-umbrae
It is completely mesmerizing ...
Enjoy !
Enjoy !
Re: Amazing animation made at Big Bear T 1.6 m solar telescope
The correct link is this one :
https://est-east.eu/index.php?option=co ... pot-umbrae
- Has thanked: 17667 times
- Been thanked: 8789 times
Wow!! that is just incredible
I'm looking forward to your version next summer then Christian
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
See stills no video.?christian viladrich wrote: ↑Tue Nov 30, 2021 12:01 pm The correct link is this one :
Dan
South central Indiana
USA
USA
- Been thanked: 4904 times
Christian:
Incredible animation.
Thanks for the link.
Dan, you have to click on them, then press play
- Been thanked: 16693 times
TiO. Titanium Oxide line? 705.7nm is in the deep red or near infrared if my understanding of the spectrum is right. Awesome video. Aperture and good seeing rules!!!
- dhkaiser
Duh. Thanks!
Dan
USA
USA
Does anyone make a TiO filter for amateur use? Of course those here with SHGs should be able to image this spectral line? Does it being in the near IR present any problems?
JP
P.S. It looks like our own Mark Townley has done it! https://brierleyhillsolar.blogspot.com/ ... 706nm.html https://brierleyhillsolar.blogspot.com/ ... ength.html and https://brierleyhillsolar.blogspot.com ... ember.html
JP
- Has thanked: 20435 times
- Been thanked: 10243 times
Without using a 'proper' ultra narrow band filter any longer wavelength filter will give similar results.
I've got a TiO filter too, I should use it more, but it does make the image very dark so have to increase the exposure a lot.
Mark and Alexandra, where did you get yours? Baader doesn’t seem to carry them and I couldn’t find them on Omega Optical’s website.
James.
James.
It was Omega Bob I think, but years ago. Like Mark says, just use a regular dark red James.
- Has thanked: 9144 times
- Been thanked: 6025 times
Incredibile animation, Christian, thank you for sharing
The TiO filter combines :
- the benefit of a G-band filter => you can see the intergranular bright spots,
- the benefit of near-IR filter => the seeing is improved, and the umbra of spot is not very dark, so it is easier to see the umbral dots.
The downside is that the resolution is reduced. So it is more relevant for large size solar telescopes (say > 300 mm).
Bandpass should be < a few nm.
If you be most usefull for a big Dobson equiped with a large size Astrosolar ND 3.8 (which are unfortunately no more available ...).
- pedro
- Has thanked: 14 times
- Been thanked: 6577 times
Fantastic animation Christian, thanks for sharing
Pedro Re'
christian viladrich wrote: ↑Wed Dec 01, 2021 12:21 pm The TiO filter combines :
I have a 305mm Dobson.
