Finally, I have fixed the last problems that plagued my full disk (the halo around the sun due to internal reflection). The dark-light gradient now looks smooth. Though I still see some part of the disk has blurred detail. Probably not seeing since I see this problem in every shot that I took this morning in the same spot. Is it possible that the low contrast region of the Quark caused this (the blurred region also are the low contrast due to etalon inhomogeneity).
Here is my 2 version of the full disk both in positive and inverted with colorization.
I'd like to hear your opinions.
30 Nov Full Disk both positive and negative
- minhlead
- Has thanked: 738 times
- Been thanked: 1104 times
Minh.
Loves from Viet Nam <3
My gear:
Mount: JTW Tridents GTR
Camera:
PlayerOne Apollo M-Max
My gear:
Camera:
- Been thanked: 16693 times
Re: 30 Nov Full Disk both positive and negative
Nicely done, Minh! Thanks for the view!
- minhlead
Thanks, James
Minh.
My gear:
Camera:
My gear:
Camera:
Thanks Minh for your renditions, particularly showing the number of proms today
- minhlead
Thanks TerryEGRAY_OBSERVATORY wrote: ↑Tue Nov 30, 2021 8:38 pm Thanks Minh for your renditions, particularly showing the number of proms today
Minh.
My gear:
Camera:
My gear:
Camera:
- Has thanked: 17667 times
- Been thanked: 8789 times
Wow! the inverted really sings
Can you show a single pane to see where the blurred bit is? I am not sure where in the full disc are the problems in relation to each pane.
- Has thanked: 9144 times
- Been thanked: 6025 times
- minhlead
This is single panel shot. I used a 2 inches reducer to get the FD to fit into my tiny 174 chip with my Quark. But as I said in my latest post, it seems I am taking too long exposure at 2ms. 0.5ms work much better with less blurred detail so I think I'd stick with shorter exposure time for now.
Minh.
My gear:
Camera:
My gear:
Camera:
- minhlead
I do love the inverted, especially when colorized. The proms show up much more naturally on inverted. But positive have higher contrast IMO.
Minh.
My gear:
Camera:
My gear:
Camera:
